Best mod for stability at high speed?
Old Sep 3, 2005 | 11:56 AM
  #41
RED99's Avatar
RED99
The corvette is designed to run at high speed and be stable. If you are feeling loseness in the front end, then something is wrong. If the car is stock and you just put on new tires, then shocks & alignment more than likely needs attention. I would check both and not chance anything if you are wanting to drive fast. If you have done any mods that can affect handling, then I would look at that Mods first. The 17 and 18 inch rims are the correct size. From what I have read, you want to always run 1 inch bigger dia. rims on the back. I think it more has to do with the active handling control.
I could just be the road you drive on too! Did it have ruts from winter tires? My old GY EMT's would road wander bad on rutted roads. The new Michelin Pilot Sports ZP doesn't do that anymore.
Old Sep 3, 2005 | 12:36 PM
  #42
Bill Dearborn's Avatar
Bill Dearborn
I agree with these comments. Had a 97 for 6 years and tracked it from the time it had 2K miles on it. Never had a high speed stability problem even with a bad factory alignment that caused the rear tires to wear out on the outside at 4K miles. My 03 Z is just as stable at these high speeds (150). I solved the GY EMT tire wander problem on my 97 by adding a little toe in at the front Vs the 0 or little toe out the factory specs allow. The car should feel more and more planted on the road as you go faster. There is a speed at which a rear wing like John Shiels has will add some stability but you aren't going to run those speeds on the street.
Bill
Old Sep 3, 2005 | 04:16 PM
  #43
Sportsdude's Avatar
Sportsdude
With MCM hood, it's very stable at 177. Still need to find a clear road to test out the top end.
Old Sep 3, 2005 | 04:43 PM
  #44
NSTG8R's Avatar
NSTG8R
mine was stable up to one oh sixt.. six. 106. never would i ever have gone 165 .. nope.
and if i had i definitely wouldn't have said it were VERY stable.
Old Sep 3, 2005 | 05:53 PM
  #45
Chris.Shea's Avatar
Chris.Shea
mine is very stable at 171mph. make sure your on a good road surface because at 150 you will know your hit a dip or bump. may i suggest you dont just hop in the vette and do a 165 plus mph pull. build yourself up and at least have alot of 120+mph pulls. imo the faster a car can get to 150 the safer it feels because when you start thinking about all the bad things that can happen you loose focus on what you should be doing (driving).
Old Sep 7, 2005 | 08:01 AM
  #46
spinedoc77's Avatar
spinedoc77
Ive had lots of 140-150 pulls with my old SL500 (rock solid) so am no stranger to the high speed.
Vette is going into a specialty speed shop today to get high speed balanced and aligned and have the front end checked out.
Old Sep 7, 2005 | 11:09 AM
  #47
TESTOSTERONE C6-R's Avatar
TESTOSTERONE C6-R
Problem solve
Old Sep 7, 2005 | 03:57 PM
  #48
LRD VDR's Avatar
LRD VDR
Originally Posted by TESTOSTERONE C5-R
Problem solve
How the hell is that wing mounted??
Shahram
Old Sep 7, 2005 | 05:13 PM
  #49
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Originally Posted by sailohio
OK. A fellow I work with races his modified 1999 C5. 160 to 200 mph. He told me the BSM (body side moldings) are functional at high speed. On a C5 the airflow comes over the hood, down the side of the car in the door area and under the car. The air under the car creates lift and the instability you feel. BSMs deflect the airflow away from the car. There is also a slight downforce created by the 160 mph airflow on the moldings. Does your car have BSMs?
That is why you see rocker panels on cars similar to mine. Wind and body gives you downforce but you loose top speed from drag. You do get faster lap times.
Old Sep 7, 2005 | 07:40 PM
  #50
spinedoc77's Avatar
spinedoc77
Well got it back from the speed shop, 4 wheel alignment and high speed balancing, but did not get a chance to test it out since now I have another problem, it is bogging down erratically. Sigh seems like these are in the shop a lot.
Old Sep 7, 2005 | 07:51 PM
  #51
Steve Thomton's Avatar
Steve Thomton
I just came back from the MKM Pony Express 130 www.openroadracing.com I had the oppurtunity to drive 129.9 miles of beautiful NV route 305 at an average of 130 mph (these are more like rallies than races, the idea is to AVERAGE a target speed over the course). This is all legal and supported by the Nevada Highway Patrol. Anyway, my 1999 C5 coupe (with 41,000 miles) has 2004 Z06 springs, shocks, sway bars, lowered 3/4 inch, and Z06 suspension settings riding on BFG KD's (fronts 265/35 18s, rears 295/35 18's on Mallett 18x9.5 fronts and 18x11 rears) ....the car was ABSOLUTELY STABLE at all speeds. I was clocked at 161 (speedo read a bit higher), which I saw about half a dozen times during the run, and averaged 129.974 over the 129.9 miles.......so I was cruising much of the hour at speeds over 140, including sweeping turns. Oh, and I don't have BSM's So IMHO you don't need alot of add-ons, just good basic C5 set up.
And if you want to have more fun than you should legally be allowed to ...... check out the open road racing scene in Nevada, that'll get your heart rate up.
Old Oct 23, 2005 | 01:16 AM
  #52
Jeffyvette's Avatar
Jeffyvette
Default Go Open Roading
I fully agree fully with Steve. Try open road racing. I have been doing it for years. I am no hitting speeds verfied radar of 200+.
Jeffy'
