Gas!
Using a higher octane rating than you need is just plain silly because, despite what people would like to believe, higher octane fuels do not produce more power and, in fact, may cause worse performance in and of themselves.
You'll hear all manner of rationalisations for the emotional case of using the most expensive; it's only a few pennies, it's a 50K sports car, my baby deserves the "good stuff" versus the "bad stuff", but the real answer lies in understanding how an internal combustion engine works and what an octane rating is all about.
Use premium unleaded gasoline with a posted octane of 91 or higher for best performance. You may also use middle grade or regular unleaded gasoline rated at 87 octane or higher, but your vehicle’s acceleration may be slightly reduced. If the engine octane is less than 87, you may get a heavy knocking noise when you drive. If this occurs, use a gasoline rated at 87 octane or higher as soon as possible. Otherwise, you might damage your engine.
and a Tier 1 gasoline that has Techron is perferable. A higher octane number means that the flame spread rate of the fuel upon ignition is slower thereby retarding knock. Using a fuel with a higher rating than necessary will actually reduce performance slightly. The oil companies have done a good marketing job on the public about using Premium Gas. Using a higher octane rating than you need is just plain silly because, despite what people would like to believe, higher octane fuels do not produce more power and, in fact, may cause worse performance in and of themselves.
i use 93 personally
The only reason that you should need to go to a higher octane than 91 for the stock LS1/LS6 engine is if your getting some detonation (engine knock). Even then, you might want to consider trying a different brand of gasoline first. As mentioned above, there is a lot of misunderstanding of what octane is and does and octane in itself does not increase horsepower.
I'll sum it up for you: you can use the LOWEST octane that doesn't cause PINGING (detonation), but it may cause a slight drop in performance. Higher compression engines need higher octane, but how high (or low)? 87? 89? 91? You just have to try it to find out. Higher octane does not mean more "power". It is a "detonation" rating. ALTHOUGH: "your knock sensor can compensate for low octane fuel by retarding the spark, at a cost in performance. But the reverse is not true. Once octane is high enough to allow optimum spark advance, more octane doesn’t help, because greater than optimum spark advance does not increase performance." So how do you know if you are still acheiving maximum spark advance using the lowest octane? Hell if I know.
At least that's what I got after reading that post. Please correct me if I'm wrong.
For some reason, people associate octane with horsepower but that relationship does not exist. The number of BTUs in a given fuel is not predicated upon its octane rating octane. Hence, higher octane fuel has no capacity to produce more power than lower octane fuel.
However, a particular higher-compression engine may need a higher octane fuel for it to produce maximum power compared to another but, again, if you overdo it you run the risk of incomplete combustion and you lose power.
So, again, you use the octane rating that allows your engine to produce peak power. Stuffing in 100 octane fuel to an engine that only needs 91, wastes money and power.
Years ago when 130 octane Avgas was availible, I knew a Guy who thought it would be great in his car. It didn't take long before his exhaust valves were burnt as the Avgas was still burning as it was exiting. The Avgas worked fine in a low rpm aircraft engine, but not in a car. Tetraethyl lead was added to slow the flame front at ignition and reduce detonation. The more lead the high the octane rating and the slower the gas burned.
