Need data on LS7 cam/valve train...
Old Sep 4, 2005 | 10:52 PM
7.0sc SuperVette's Avatar
7.0sc SuperVette
From: Sunny Earthquake Country, USA On the Left Coast (which is becoming more Right!)
Default Need data on LS7 cam/valve train...
I remember seeing data but did not write it down and can't find magazine now.
Especially what is LSA-I think it's something like 117-119 degrees?
I think the lift on the intake is .591" in only 211 degrees (@ .050")-is that due to Ti pushrods and valves or other magic? What is the Spring dia?
I am thinking of having Comp Cams make up something similar for my C5.
May the BOOST be with you!
Roy
Old Sep 11, 2005 | 03:45 AM
7.0sc SuperVette
Default Help!...
Hey! I sure some of you know something about the new LS7, Help me out here!
The LS7 seems to have a cam that puts all the after market cam grinders to shame and I would like to have a custom cam patterned after it for my C5 (and probably so would you, if you have a street machine)!
What do you know?
Roy
Old Sep 11, 2005 | 05:21 AM
Mitch C's Avatar
Mitch C
I believe the LS7 cam is 211/230 591/591 120 LSA. The LS7 is way under cammed and should put out a great deal more power when LS7 owners upgrade to a bigger cam. As for your LS1, there are better cams out there than the LS7 cam. cheers:
To Need data on LS7 cam/valve train...
