Turning lights...
Old Sep 8, 2005 | 03:12 PM
Erik88vette's Avatar
Erik88vette
Default Turning lights...
Can someone tell me how to remove the turninglights on the front.
Should I remove the inner fender(plastic) or what.
Mine seem to be loosened or never been bolted.
Maybe some pictures on how to fix them.
Greetz Erik.
Old Sep 8, 2005 | 11:05 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Patches can help you out probably...the guy is a God with that stuff.....may want to PM him...he has everything
Old Sep 9, 2005 | 09:33 AM
jaxgator's Avatar
jaxgator
From: Time is a great teacher. Unfortunately, it kills all its pupils.
Cruise-In VIII Veteran
St. Jude Donor '07
I take it you are asking how to remove or gain access to the entire housing? If so, there is an access panel on the underside of each of the front corners of the bumper. They come off with about six or seven 7 mm screws IIRC.
To completely remove the housings you'll need to get the brake duct out of the way. Then there are two fairly small screws (don't remember size), one on either side of the curved turn signal housing. Take both of those out and then remove the spring that is on top of the housing. Finally, disconnect the electrical connections and remove the housing.
Old Sep 9, 2005 | 12:39 PM
Erik88vette
Thanks for the info...great forum
Greetz Erik.
Old Sep 9, 2005 | 04:36 PM
QuikZilver's Avatar
QuikZilver
Bolt on side of housing is 7mm. Bolt towards the center of the housing is 10mm. Just replaced mine 3 weeks ago. Not hard to do.
Old Sep 11, 2005 | 05:54 AM
Erik88vette
Yes finally fixed the problem,one screw missing and the spring on top was also gone.
A special thanks to Jaxgator and Patches who really helped me out here.. .
As I said before...GREAT FORUM..keep it up.
Greetz Erik.
To Turning lights...
