B0361 H C Does not clear after i Reset
Old Sep 5, 2005 | 06:14 AM
Jetspeedz's Avatar
Jetspeedz
Default B0361 H C Does not clear after i Reset
What the hell is wrong with this car... it just drives me nuts how it throw codes out of no where and there are no obvious problems...
i get the B0361 code and i reset the code and it does not go away it keeps coming back right after i rest...
so i turn off the car and turn it back on and try to reset it again and it resets and shows zero errors then i scroll up or down on the code list and go back to HVAC and its there again...
i know it has to do with the left actuator .. but where is this located and this started happening after i cleaned the dash (center AC vent) by just dragging a rag across the top...
And I did a search and found some useful info but didnt really answer the question where its located
Old Sep 5, 2005 | 08:05 AM
JR_VETTE's Avatar
JR_VETTE
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
http://forums.corvetteforum.com/show....php?t=1177504
I would recommend disconnecting the battery before you look into anything else.
Old Sep 5, 2005 | 05:40 PM
Jetspeedz's Avatar
Jetspeedz
thanks ill try that
To B0361 H C Does not clear after i Reset
