A/C Compressor working but not pumping
I wish I could say they're easy to install.
Some reports suggest to take out the rad and move the compressor forward. Others report to take out the exhaust manifold to move it back before tipping it up.
On my '01 removing the water pump was the most expeditious way.
Don't forget the water pump gasket in advance... or it will build down time.
I bought my replacement a complete used compressor with clutch assembly from Gene at Gene's Karshop delivered for less that the parts of the clutch assembly locally.
It's back together and working fine
Check the DTC Codes in the DIC. Your HVAC is monitored by the DIC! Check and post all of the codes! That is the very first thing that needs to be done!
Common failure points are:
1- Bad interior temperature sensor.
2- Bad exterior temperature sensor.
3- Bad grounds.
4- Low on Feron! (compressor will cycle on and off or may not even run!)
Are you confusing the pulley turning vise the compressor clutch locking down and actually spinning the compressor internals???? Look directly at the front of the compressor. The hub in the center connects to the spinning outer pulley when 12 VDC is applied to the electromagnet clutch in the center of the hub!
You cant just change out the compressor!!!!
There are numerous other steps that you must take prior to installation of the new compressor!!!!
You need to figure out why the other one went bad (if it truely is bad!) and if any debreis are in the system. If there are, you need to flush out the system and install a new orface tube and new receiver/dryer. Then you need to add the required amount of referigent oil (the proper type)
Then you M U S T draw a vacuum on the system and refill it with the EXACT amount of freon or your going to be in the SAME condition that your in right now!
PLEASE! Start with reading the codes in the DIC and post them here! That will get us in the right ball park and maybe save you a lot of time and a grunch of money!
Yea, Im sure that there are a number of folks who are going to say that they ripped out their compressor and just installed another one and it worked!
They got very lucky and most likley the compressor wasnt bad to begin with! If you have moisture in the system when you recharge it, it will cause acids to form inside the evaporator and eventualy, tiny pin holes will develop causing MASSIVE dollars to flow from your wallet!
3- Bad grounds.
