CHECK ENGINE LIGHT!: Lean codes?
Old Sep 6, 2005 | 03:10 PM
sandmanusd's Avatar
sandmanusd
Default CHECK ENGINE LIGHT!: Lean codes?
Well, my Check Engine light just came on... I just installed my Halltech Stinger on my Z06... I checked the codes, the only ones showing are 171 and 174, the lean fuel codes... would this cause the check engine light to come on?
And also, how do I remedy this problem so my computer adjusts for the increase in air flow?? I remember there being a write up on how to "learn" your computer how to do this:
Old Sep 6, 2005 | 04:12 PM
jay'szo6's Avatar
jay'szo6
I have the same year and color Z as you. I also have the same intake. So we both have the same lean code problem. I too have searched for a remedy, and have yet to do so. I've added some other mods since, so i'm going to go for a dyno tune in the next week or so.
Halltech has this that sounds like it would definatley fix it:
http://www.corvettec5.com/store/?pag...f23c49ea9795be
I think a forum member has tried this and hasn't had any problems since.
There is also this cold air mod, that the shop manager from the shop i'm going to have dyno tune my Z, said would clear the code. It's cheap, and will send more cold air to the filter. Instead of sucking in the warm air from the engine compartment. I'll let you know how it goes.
http://www.conceptualpolymer.com/corvette_c5_corner.htm
Old Sep 6, 2005 | 10:47 PM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
Get a realtime tune from a local tuner. It will take care of your problem. Happened to me also after a stinger install.
Old Sep 7, 2005 | 12:14 AM
rws.1's Avatar
rws.1
The PCM can adjust for 25% more air as the new induction system leans out the system.
Did you drive for at least 50 miles... at 55 miles per hour?
Old Sep 7, 2005 | 01:24 AM
Jim M's Avatar
Jim M
St. Jude Donor '08
There's two ways to eliminate the codes and check engine light, common on late Z06s when using the Halltech stinger; use a screened MAF or have the car tuned. The screened MAF worked for me.
Jim M
To CHECK ENGINE LIGHT!: Lean codes?
