Intermittent AC Operation
Old Sep 8, 2005 | 10:57 PM
lt4-racer's Avatar
lt4-racer
7th Gear
Default Intermittent AC Operation
Let me know if anyone knows what is wrong with the AC on my '97 coupe with climate control.
About 40% of the time I start the car, the AC display and AC functions are completely dead. Sometimes I can turn off and restart the car to restore normal operation, but other times that doesn't work. There are also times that the dead AC returns to operation on its own after I've driven around for a few minutes. Likewise, the AC sometimes goes dormant on its own after it has been running.
I checked with a couple of the online control unit rebuilders, and they both said that they couldn't help. One said he thought it might have something to do with the ignition switch. My shop manual offers no insight.
It's pretty hot where I live, and this is driving me crazy. Please help.
Old Sep 9, 2005 | 06:57 AM
rws.1's Avatar
rws.1
Did you check with David Ruberg? digitalguy_1@charter.net.
I believe he lists a problem like yours that he can fix.... although the intermittent nature might be the difference.
Old Sep 9, 2005 | 07:32 AM
lt4-racer's Avatar
lt4-racer
7th Gear
He was one of the two that I tried earlier. He told me to get a used one from a bone yard because his fix wouldn't work for me. Carl Cowles was the other one I tried who said that it seemed like an ignition switch problem.
Old Sep 9, 2005 | 09:26 AM
Crispyc21's Avatar
Crispyc21
Listen to the guy that said it's the ignition switch. A couple people on the forum was/is having the same problem. I was one of them. The ignition switch was the problem. I just replaced mine last weekend and my AC problem went away. Here are a couple threads you can look at.
http://forums.corvetteforum.com/show....php?t=1167013
http://forums.corvetteforum.com/show....php?t=1154441
If you replace it yourself, it's not hard. It took me a couple hours and I went slow. You just remove a couple console panels and access the switch from the bottom.
Old Sep 9, 2005 | 07:43 PM
lt4-racer's Avatar
lt4-racer
7th Gear
Wow! That's exactly the kind of info I hoped for. I tried the back up lights on my car, and they do go out along with the AC. I'll order an ignition switch right away (Autozone has one for $27). Thanks!!
Old Sep 9, 2005 | 09:40 PM
Crispyc21's Avatar
Crispyc21
That's a good price. Good luck, I hope it works out. Keep us posted on how it goes.
Old Sep 9, 2005 | 10:08 PM
edensknight's Avatar
edensknight
In general, if you are not trouble coding for faulty temperature actuators, and, your AC vacuum hoses are also intact (i.e., leaky o.e. batteries have been known to eat throught the AC hoses that lie below and aft of the o.e. battery in the C5 Corvette engine compartment, and, will consequently throw B0361 HVAC trouble codes, as well), "intermittant AC function" is usually symptomatic of a faulty ignition switch as stated above. Please let us know how everything turns out for you.
Best Wishes,
Eden
Old Sep 13, 2005 | 10:26 AM
Crispyc21's Avatar
Crispyc21
Any luck yet??
To Intermittent AC Operation
