Headlight retraction problem
Old Sep 10, 2005 | 12:01 AM
Tigershark3's Avatar
Tigershark3
Default Headlight retraction problem
Hi All... new to Corvettes..... I've had my '99 for about 2 weeks and everytime I drive it it feels sooo good. Anyway, I've got my first problem and I'm hoping someone here can help me. My right headlight... it opens fine but when I close it, it closes ok but when it hits bottom it sounds like the motor keeps running and the gears grind for about 3-5 seconds then stops. The tech at the GM dealership looked at it (for free - nice guy) and thought it was a bad motor and most likely it would only get worse. I priced a new motor and they run about $250 - Yikes!
Thanks in advance
Old Sep 10, 2005 | 12:05 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
All it is, is the headlight gear. Its a plastic gear that eventually looses the teeth and starts to grind. Check with any one of our vendors. They sell a brass gear that will never wear out. It is only a couple bucks. You should be able to fix BOTH headlights for less than 50 bucks.
BTW, New headlight motor?? Thats complete
Old Sep 10, 2005 | 12:17 AM
Avanti's Avatar
Avanti
No, not necessarily the gear (probably not from your description). It is likely the actuator that keeps on running on... about $350 installed at the "stealer."
Btw, a reason they don't come with bronze gears is that when/if the actuator goes out the metal gear works like a saw on the other gear. I'd NOT install the metal having had an actuator go.
All the best.
Old Sep 10, 2005 | 03:17 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
All the best.
I may be wrong (probably not) I had the exact same thing happen to me and it was my gear that was bad.
Plus, when you do a search under grinding headlight gear you get 31 matches. Most all of which are like this..
http://forums.corvetteforum.com/show...r&forum_id=103
http://forums.corvetteforum.com/show..._id=103&arch=1
I could post about 20 more but I think you get the point
BTW, Its your gear.
Old Sep 10, 2005 | 06:03 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
If you want pics and a how to DIY PM me and I will email them to you
To Headlight retraction problem
