aftermarket wheels
With some wheels you can bolt the sensors in just like stock, others you can't do it that way...But you can install a sensor in ANY wheel, no matter what brand or size.
What wheels are you considering?
Mine have been mounted this way for over 30k miles, just had new rear tires mounted this year, they were still holding strong.
It's not tough to do, and I certainly wouldn't choose a wheel based on ease of sensor mounting. I spent about $30 in materials and a total of a half-hour to mount the sensors as pictured. Once mounted, they are there for a long, long time and obviously not visible. The wheels themselves are always visible
Get the wheel you really want, then cross the bridge of mounting the sensors.
Which is exactly why I had to mount the sensors as I did.
page 213
Clamp Kits
Screw and housing attach to the banding to form a secure clamp. Band splicer lets you connect extra banding to form a larger diameter clamp.
Housing and band are Type 301 stainless steel. Screw is Type 410 stainless steel and tightens with a wrench, slotted screwdriver, or 5/16" hex nutdriver. Torque is 50 in.-lbs. Temperature range is -50° to +250° F. Meet SAE J1508. Not recommended for use with silicone hose and tube. For silicone compatible clamps, see 95885K on this page. No. of No. of
Band Band Band Screws Band
Lg. Wd. Thick. and Housings Splicers Each
8 1/2 ft. 1/2" 0.023" 3 ea. 1 5426K1 $10.24
50 ft. 1/2" 0.023" 10 ea. 5 5426K2 31.94 <----- This one
100 ft. 1/2" 0.023" 25 ea. 10 5426K4 65.20
Replacement Parts Per Box
Box of 10 Screws and Housings 5426K3 $14.76
Box of 10 Band Splicers 5426K6 .72
Box of 10 Band Splicers and 100 ft. Band 5426K7 32.91
Band Splicer
You will need the 31.94 kit (5426K2), and also some two step epoxy, you need to do both things.
Make sure you place the sensor as deep as possible in the rim and also make sure you place it in line with the valve stem so you will know where it is when you train the sensors. You will need to place a magnet as close as possible to the sensor for the learning process.
page 213
Clamp Kits
Band Splicer
Just make a small mark on each wheel (rf, lf, rr, lr) before you remove the tires. then transler the sensor to the new wheel, mark the new wheel with the same designation, and then make sure the tire guy mounts the tires properly for that wheel's location if you are using directional tires.
