changing plugs
Old Sep 11, 2005 | 01:11 PM
pieplow's Avatar
pieplow
Default changing plugs
is there anything special i have to do in removing the spark plug wire from the plug? there is some type of round metal shield around the plug that is lose but when i pull on the wire it seems very tight. i don't want to pull on something that has a release of some kind that i don't know about.
i've got my eight plugs and am ready to replace. if all i need to do is pull the wire harder, please let me know - i just don't want to break something i shouldn't.
Old Sep 11, 2005 | 02:01 PM
3 Z06ZR1's Avatar
3 Z06ZR1
Never grab the wire, grab the boot itself as low as you can,slight twist.
Reuse the heat sheilds. Coat the inside of the plugwire boot with die electric grease.
Old Sep 11, 2005 | 02:12 PM
vetpet's Avatar
vetpet
Old Sep 11, 2005 | 02:46 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Also, you are going to need an extension and a 90 degree "knuckle" get get the ones on the back driver's side. Save yourself 1/2 hour fighting with the plugs and go to sears and pick one up. IMHO
Old Sep 12, 2005 | 07:25 AM
vettenuts's Avatar
vettenuts
First time I changed the plugs, the wire removal was the hardest part, well except for number 7 maybe
Old Sep 12, 2005 | 09:03 AM
lost's Avatar
lost
I removed and replaced mine with nothing more than a socket, extension, standard swivel and a spark plug wire removal tool and a flat blade screw driver to remove some of the clamps,hoses etc that make #7 so difficult.Took less than 2 hours working at a very leisurely pace.
Old Sep 12, 2005 | 10:37 AM
Dustie's Avatar
Dustie
Default plugs
Here's the tech tip link.
https://www.corvetteforum.com/techti...ID=7&TopicID=1
One thing there is some discussion about is how to treat the threads on the new plugs. Some use a small amount of anti-seize but GM recommends only a drop of motor oil. You choose.
I did mine last winter and it was easy, but I have small hands.
To changing plugs
