Race Wheel Studs
Old Sep 11, 2005 | 07:26 PM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
Default Race Wheel Studs
This may be a fairly uninformed question, but how much longer wheel studs do most people run than stock for the track?
The reason I ask is that I'm contemplating using dedicated track tires next season and know most use longer studs. I'm also looking into some spacers for street driving purely for asthetics. Maybe I could find a happy medium.
Thanks in advance!
Old Sep 11, 2005 | 07:56 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
ARP studs or GM racing studs which are longer and CCW will make you spacers
Old Sep 12, 2005 | 06:03 PM
BQuicksilver
John, my big question was how much longer? That will guide my spacer choice.
Old Sep 12, 2005 | 06:23 PM
John Shiels
I run .850 spacer and the standard ARP has plenty of thread for that. If I got them from DRM GM race studs are even longer/
Old Sep 12, 2005 | 08:17 PM
AU N EGL's Avatar
AU N EGL
I have ARPs also - about 3 1/3" long Got them from Summit Racing dot com
Also have some harded open ended lug nuts from NAPA
I also use a spacer 3/8" on the rear.
Old Sep 12, 2005 | 08:51 PM
BQuicksilver
Is the photo above with no spacer?
Could I see a shot of:
1) The studs with lugs on your spacered rear wheel.
2) A close up of the lugs you use. Are they silver or yellowish?
Old Sep 12, 2005 | 11:54 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Kodiaks, which are a popular wheel in SCCA T1, require longer wheel studs. I run CCWs, 17x10 front and 17x11 rear with stock wheel bearings and studs. I replace my wheel bearings and studs about annually.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Sep 13, 2005 | 03:14 PM
FOAMY's Avatar
FOAMY
4th Gear
The delphi cartridge bearing for the C5/6 will easily accept the ARP p/n 100-7704, 1/2 x 20 x 3.470 uhl wheel stud.
A simple drill through to clean the press knurl (of approx 0.060"), then drill guide diameter for 1/2" (drill 29/64") and then tap 1/2 x 20.
This not only makes continually replaceable, but the other available knrul diameters do not really fit past the wheel bearing/wheel speed sensor cartridge. The 0.568, 0.618, 0.625 and the 0.680 knurl fastners have a hard time making it past the bearing assembly on its way to the flange...... not to forget to mention, after a replacement or two, the knurl interfearence fit just goes away.
Old Sep 18, 2005 | 03:21 AM
BQuicksilver
TTT, anyone know the exact length of the stock wheel studs?
Old Sep 18, 2005 | 06:51 AM
AU N EGL's Avatar
AU N EGL
This photo below is the rear wheel with spacer.
The studs themselves are light brass colored. Depending on the light sometimes they look silver / steel colored
dont have a close up. Look at summitracing.com
Part # ARP-100-7708
more photos at http://photobucket.com/albums/v172/AUNEGL/?start=40
Old Sep 18, 2005 | 12:19 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
I purchased 1/2" longer studs from Mallett. They also have longer sizes available.
VR
Old Sep 18, 2005 | 02:58 PM
BQuicksilver
Thanks for the advice, VR.
AU N EGL: Nice photo album. I love how the yellow car sits. I'd love to get to VIR someday.
Old Sep 18, 2005 | 03:02 PM
John Shiels
i'll meaure some today
Old Sep 18, 2005 | 03:20 PM
BQuicksilver
Thanks John, I'd really appreciate that. I'm trying to decode how much spacer I want for street and how much extra stud I need for Kodiak FX's without spacer to get the right length of wheel stud without being dangerous on track or having it look crummy on street.
Old Sep 18, 2005 | 03:24 PM
BQuicksilver
Part # ARP-100-7708
So the stock lugs are 12mm x 1.50rh?
Old Sep 18, 2005 | 04:28 PM
John Shiels
arp is 2.5" shaft + .15" head or 2.65" overall
stock 1.95" shaft +.18" head or 2.13" overall
Hope you know what I mean
Old Sep 18, 2005 | 04:38 PM
BQuicksilver
Hehe, thanks for holding my hand through this.
You said you run a 0.850 spacer, how does that work when the ARP stud only gives you an extra 0.5 inch over stock? I assume the foot of the wheel you run is thinner? Just trying to make sure I have a grasp on all this.
To Race Wheel Studs
Old Sep 18, 2005 | 07:43 PM
John Shiels
front CCW is thinner than rear by maybe 50% just a guess. No spacer in rear. CCW makes nice spacers and he may know what you need exactly. Your spring rate will change as you space the wheels out. How big of a rush are you in? I will have it apart next weekend.
Old Sep 19, 2005 | 12:22 AM
BQuicksilver
No super big rush here. The spring rate/handling change shouldn't bother me since spacers are just an asthetic choice for me. I'm stil trying to guess what spacer I need to set the wheels flush with the fenders.
Old Sep 19, 2005 | 05:51 AM
John Shiels
just plumb down the edges with a level when the car is level. Doubt you want to go more than 850 which is slightly more than 3/4"
