Traction Control off means hotter engine profiles?
Old Sep 11, 2005 | 10:11 PM
Bluemill's Avatar
Bluemill
Default Traction Control off means hotter engine profiles?
I was getting my annual inspection sticker the other day and was biding my time in line by talking with a mechanic who seemed interested in my 2000 coupe 6 speed. He said he had a 2005 GTO with the LS2 engine and 6 spd. He told me that the traction control off setting puts the engine in much higher performance ignition and fuel injection timing profiles. He also said you would get better fuel economy. I told him my understanding was that if you started to slip on a rear wheel under load that the ABS would kick in and reduce fuel to the engine. It would only do this when you lost traction. Who's right?
Also, I have got a nagging soft rattle in the firewall/driver side dash area that I've put a lot of work into. I thought for sure that it was the HUD projector, but after removing the whole dash, the whole instrument cluster, and the HUD unit, it still does it. Could there possibly be anything in the heater core/evaporator area that could do this? It does it all the time but is most noticable at 30 mph when going over "cracked" or older asphalt.
Thanks for any help you can offer-
Bluemill
BUY AMERICAN!!!
Old Sep 11, 2005 | 10:16 PM
STA-BLK's Avatar
STA-BLK
Bluemill
BUY AMERICAN!!!
Question one,he is an idiot.
Question two.I had the same problem,turned out to be the a.i.r pipes hitting the firewall behind the drivers side head.Might be a fix for ya,good luck!
Old Sep 12, 2005 | 01:24 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
He needs to get better edumactaed in C5 and F body stuff. Thats just WRONG info!!!
BC
Old Sep 12, 2005 | 02:12 PM
yellow01's Avatar
yellow01
Damn! Here I thought I was getting an extra 20hp when I turned that stuff off...
Old Sep 12, 2005 | 02:51 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Go around back and see his "GTO". A tricked out Corella, Way to may people talk out their azz
Old Sep 12, 2005 | 03:15 PM
David426's Avatar
David426
Actually the traction control when deactivated sprays nitrous oxide into the intake. When it is activated it recharges the nitrous supply by reverse osmosis...
Old Sep 12, 2005 | 04:13 PM
TarHeelDan2001's Avatar
TarHeelDan2001
Old Sep 12, 2005 | 04:28 PM
RED99's Avatar
RED99
Maybe he got TRACTION CONTROL mixed up with EMERGENCY BRAKE!!!
Old Sep 12, 2005 | 04:45 PM
Ken1234's Avatar
Ken1234
I think you may want to seek another mechanic.
Old Sep 12, 2005 | 06:08 PM
Ttop34's Avatar
Ttop34
I remember something like that on the Pontiac GTP, kind of. Instead of cutting back throttle to re-gain traction, it would cut back your timing. The system seemed not to work because you could still leave 50' of rubber with the Traction Control on, lol.
Old Sep 12, 2005 | 06:15 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
I second the AIR tube rattle. I ended up just putting a piece of heater hose over that section and zip tying it in place. As far as magic timing/fuel maps, you have to purchase a $68 electric supercharger to realize the maximum gains.
Old Sep 12, 2005 | 06:22 PM
vetterlatethannever's Avatar
vetterlatethannever
Learn something new everyday
Old Sep 12, 2005 | 07:12 PM
David426's Avatar
David426
It was a joke man, I was'nt serious
Old Sep 12, 2005 | 09:17 PM
RED99's Avatar
RED99
Old Sep 12, 2005 | 10:24 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
sta-blk and fastguy, nice find on the AIR tube rattle, i had recently was in there to replace the check valve(code p1416)was the one BEHIND the intake manifold, i spent/waisted some time trying to get at it then pulled the intake manifold(15 mins if you don't have to mess w/ the t/body coolant hose)then no prob getting to the AIR tube--alright i'm lying, i had to remove the entire tube to the pass side ex man. to use more oomph to break loose the threads on the ck valve
Old Sep 12, 2005 | 10:53 PM
vetterlatethannever
Duh!!! So was mine, that's why I have that little "leaving the room" smiley after saying it!!
Old Sep 12, 2005 | 11:40 PM
LS9's Avatar
LS9
To Traction Control off means hotter engine profiles?
Old Sep 13, 2005 | 06:37 AM
AFVETTE's Avatar
AFVETTE
I had the same problem after installing some LT headers and after handling and moving stuff around the air tube was just slight out of shape and was hitting a protruding bolt from near the master brake cylinder. After weeks of this driving me crazy a buddy came over with a very bright led flash light and shined it down in the area, sure enough you could see the pipe laying on the bolt. We tried using a VERY long flat blade screw driver to pry it away but that didn't work. So we cut some old black garden hose I had put a slit on it and slide it over the air tube. Problem solved.
Good luck
Tom
Old Sep 13, 2005 | 11:56 AM
Special K's Avatar
Special K
word.
Old Sep 13, 2005 | 10:22 PM
bigsal01's Avatar
bigsal01
hahahaha
