Low octane C5
Old Sep 12, 2005 | 10:01 AM
bozo4onion's Avatar
bozo4onion
Default Low octane C5
Has anyone converted or detuned the C5 for use with low octane fuel. With gas prices so high I would think some daily drivers might want to sacrifice some horses for cheap gas. Thanks and flame suit donned.
Old Sep 12, 2005 | 10:30 AM
Mike04's Avatar
Mike04
If you can't afford the gas you can't aford the car.....
Old Sep 12, 2005 | 11:07 AM
chasswartz's Avatar
chasswartz
The c5 will run on 87 octane, the manuel says it will have less power, but i have not noticed. I have a 03 with 70,000 miles, most of them on 87 octane. It will not hurt your car.
Old Sep 12, 2005 | 11:16 AM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
the C5 detunes it's self when you use 87. The computer retards the spark advance.
Old Sep 12, 2005 | 11:43 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I run mid premium all of the time! It works fine even in my Z06. If I need to run her hard at the track i fill it up with 93. If your just commuting and not running it hard, mid premimul will work JUST FINE! I have never tried 87. If I were in a pinch, I wouldnt have any issues doing it. Just remember that you cant play and I would add a bottle of chevron techron fuel system cleaner at every other tank full.
BC
Old Sep 12, 2005 | 12:10 PM
wyndzer's Avatar
wyndzer
Around here the high test is usually 20 cents more than the regular, so for 20 gallons that's $4 more, or a little more than an extra gallon. Either don't buy a pack of smokes or use 1 less gallon of gas and you have made the difference
Old Sep 12, 2005 | 02:52 PM
99 vett babycar's Avatar
99 vett babycar
bozo4onion, the answer to YOUR QUESTION is yes. The car is set-up to run on 87 octane, but with lowered performance for those 165 mph runs you usually do on your way to work. There IS a reason GM engineers like Evil Twin put that program in the car originally - to allow the use of lower octane without causeing damage to the car, should the owner and payer of the car want to do so. .
Old Sep 12, 2005 | 03:03 PM
MagikDraggin's Avatar
MagikDraggin
Cruise-In IV Veteran
Cruise-In V Veteran
That's funny. My stock '04 coupe pings on 91 octane. It'd probably go NUTS on 87 octane.
Old Sep 12, 2005 | 03:10 PM
tolk's Avatar
tolk
My '98 pings on 87 if I put my whole foot into it. It doesn't ping at all with 93. I thought 87 was ok for commuting but I always seem to put my foot into it.
Old Sep 12, 2005 | 03:13 PM
Ducman69's Avatar
Ducman69
Unless the Corvette is different, the engine does NOT have any way of knowing what fuel you are putting into the tank. As such, it can't auto-switch to a set of different "healthy" maps. What happens is that a knock-sensor can detect detonation and retard the timing accordingly to protect the engine from damage. But 1) knock-sensors in most cars are not that sensitive since its hard for them to filter out all the other "noise" 2) thats a reactive system. You're unlikely to grenade your system, and probably won't be concerned under light throttle and normal weather conditions... but still... its a Vette. If you're just going to work, you could get yourself an extra cheap bike (few don't break 40mpg) or pickup a little 1990 CRX HF which is rated 49 mpg / 52 mpg (set you back less than $2K for a gem... and tires and such are almost free).
To Low octane C5
