Column Lock - done or not??
Old Sep 13, 2005 | 10:37 AM
cenzo's Avatar
cenzo
Default Column Lock - done or not??
Here's my dilemma.
Called dealer to have column lock recall done on '99 A4 vert.
Dealer checks VIN and says it was done in 2001 for original owner.
However, the locking plate is still in the car...so now what do I do?
The service bulletin in the STICKY doesn't address 1999 A4s. Why is that? HELP!!?
Old Sep 13, 2005 | 10:59 AM
cliff_ford's Avatar
cliff_ford
My Euro 1999 vette was recalled in 2001 for modification. It was recalled again this year campaign # 04006B. I think you'll find this is the one that removes the locking plate on US models.
Old Sep 13, 2005 | 11:44 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
How do you know the locking plate is still there?
Old Sep 13, 2005 | 12:01 PM
cenzo's Avatar
cenzo
The steering wheel locks when I remove the key? How you doin Rich?
Old Sep 13, 2005 | 12:29 PM
screw991le's Avatar
screw991le
I am fine, the lock still engages. You can hear the pin move into place, but the lock plate should be gone. They leave the motor in place.
Mine has been make the sound right after the recall and I took it back to the dealer. They told me that story. No problems in 4 years.
Old Sep 13, 2005 | 04:01 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There was like a 3 segment recall. You could have only one part of it. make an appointment at your dealer and ask them to check and preform the entire recall.
BC
Old Sep 13, 2005 | 06:11 PM
qball's Avatar
qball
What years were effected?
Old Sep 13, 2005 | 06:49 PM
BiggieBoy's Avatar
BiggieBoy
IF your steering wheel locks after the car is shut off---you (the previous owner) did not have the recall "fix" done properly for the A4 C5. Your wheel should turn WITH the key out of the ignition if the recall was done right. As noted above---Take the car to Chevy and have then take care of the problem... Good luck.
cenzo's Avatar
cenzo
Thanks Bill.
I left the car at the dealer this afternoon. Their records indicate that the harness was installed in '01 but nothing about removing the lock plate. I guess I'll find out tomorrow what the ststus is.
Old Sep 13, 2005 | 07:19 PM
TEXHAWK0's Avatar
TEXHAWK0
Thanks Bill.
Installing the harness without removing the lockplate is obviously worthless.
The smaller plate to replace the lockplate comes with the Harness K kit from GM. The original dealer must have a pile of them somewhere.
Old Sep 15, 2005 | 03:21 PM
cenzo's Avatar
cenzo
Default Update
Day two at the dealer.
Service writer calls and says the "Tech" wants to know under what conditions the problem occurs?
I tell her the problem has not yet occurred and that's what I'm trying to prevent by having the locking plate removed!
Now I am SCARED.
Old Sep 16, 2005 | 11:24 AM
cenzo's Avatar
cenzo
Default Conclusion!
Day Three....
Dealer calls this morning. Tells me the lock-plate had been replaced with another one and the steering wheel locks just fine.
And my differential seal(s) will cost $588 to replace.
I tellem - do nothing, I'm on my way to get my car!
I'm gonna try another dealer .
Old Sep 16, 2005 | 11:31 AM
EHS's Avatar
EHS
Good luck, Vince.
I just got jerked around on this as well. See the sticky.
Old Sep 16, 2005 | 12:29 PM
SpeedyZ's Avatar
SpeedyZ
Day Three....
That is too funny!
I know some guy that work at dealers, I wouldn't let them even pump gas in my car!
Good luck
Old Sep 16, 2005 | 04:56 PM
6 speed Sid's Avatar
6 speed Sid
What a lack of understanding and knowledge of their product by the dealer.
Old Sep 16, 2005 | 05:34 PM
cenzo's Avatar
cenzo
It's not only the dealer, GM is just as bad. I've been on the phone all afternoon with the dealer and GM. They're all idiots. I'll have updates on Monday...I hope. But this is what I've learned to a certainty:
All of the A4 recalls disable the lock including the 2001 version 01044. This Forum is still the best source of accurate information.
Monday the dealer and GM will determine the next course of action. Stay tuned.
To Column Lock - done or not??
