Trunklid does not pop-up
Old Sep 14, 2005 | 11:27 AM
Hung6525's Avatar
Hung6525
Default Trunklid does not pop-up
I just bought a 2000 FRC. I love this car!!! it's fast and handle very well.
I have a very minor problem with the trunklid not pop-up. I have to pride it open with my finger. Any suggestion ??? Thanks in advance...
Old Sep 14, 2005 | 11:32 AM
vettenuts's Avatar
vettenuts
I put a little silicone on the gasket so it doesn't stick. You might also want to lubricate the release mechanism a little.
Old Sep 14, 2005 | 11:36 AM
NOSjohn's Avatar
NOSjohn
I've heard of many people complaining about this. It occurs with the FRC's and the Z06's both. We all complain about it: I do, my bud with his '02 Z06 and my brother with his '01 Z06.
I am going to try and using some white lithium grease and maybe adjusting the bumpers up but then the later might make the lid edge higher.
Personally, I think the issue has to do with the counter-acting mechanism being a hydraulic arm and the lid material not being heavy. For example - on the Chevy Monte Carlo it works fairly well as the trunk lid is heavier and it uses a bigger mechanism with springs.
So far, I've seen no solutions to fix this "issue".
CrazyChris's Avatar
CrazyChris
Also you can hit the release button then shut one of the doors. The force from the door should pop it up preventing the need to pry.
Old Sep 14, 2005 | 11:39 AM
steponc's Avatar
steponc
St. Jude Donor '14
Another item is some trunk lids only have one gas shock. Mine is one that only has one and as mentioned above the gasket cleaning or lubing helps.
Old Sep 14, 2005 | 04:32 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
The door trick works very well as does keeping the mechanism lubricated properly. Another trick is raising the two "bumper stops" in the rear corners of the trunk. In my car, an 02 Z06, there are two rubber stops in the rear corners of the trunk that screw down into the rear bodywork. I threaded these up about 1/4" to put some upward pressure on the trunk to help push it up and pop it when the release is pressed.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Sep 14, 2005 | 04:37 PM
NOSjohn's Avatar
NOSjohn
Very cool! Someone who has actually done it. That gives me something to look toward for this weekend!
Old Sep 14, 2005 | 04:38 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Old Sep 14, 2005 | 08:33 PM
cenzo's Avatar
cenzo
Default Lube it!
Raise the trunk lid and check the hinge mechanisms on each side. There are several pivot points on each that need to be lubricated. Any type spray lube will work. Lube, then exercise the lid for several cycles. Lube the latch mechanism as well. It should start to improve right away.
Old Sep 14, 2005 | 10:47 PM
striper's Avatar
striper
I had the same problem on my Z06. Someone here suggested spraying the latch mechanism with WD-40. It worked better than I thought it would, just doing that made it open at least an inch higher, every time.
Old Sep 15, 2005 | 04:48 PM
Hung6525's Avatar
Hung6525
Alright, thanks for the info everyone!! I'll give a try.
Old Sep 16, 2005 | 08:10 AM
Z06Plasticfantastic's Avatar
Z06Plasticfantastic
unscrew counter clock wise the two spring loaded bumpers on each side of the trunk lid. Don't go too far the trunk won't close. Worked on my z06
Old Sep 16, 2005 | 12:33 PM
MacVette86's Avatar
MacVette86
I followed all the fixes mentioned so far and the one that finally worked was adjusting the rubber stops. My trunk lid now pops open about an inch and a half. Thanks to everyone
Old Sep 16, 2005 | 02:02 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Had the same problem on my Vert, so I oiled the hinges and greased the struts and adjusted the bumpers. Now it works like a charm. Just don't adjust the bumpers too much or the trunk lid will sit higher than the surrounding panels when closed .
Old Sep 17, 2005 | 12:04 AM
DRR's Avatar
DRR
I had tried lubing and that helped very little but after adjusting the rubber bumpers my vert trunk now pops up like it should. Thanks to all who advised adjusting the rubber bumpers.
Old Sep 17, 2005 | 11:21 AM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
I tried all the suggestions and nothing seemed to help in the long term. One day I took a closer look at how the hoop on the trunk lid was contacting the latch mechanism and noticed that it was aligned to far to the left side or all the way back in the crotch of the lock. I removed the hoop from the deck lid and elongated the fastener holes slightly so it could move further towards the right side of the car. It has worked ever since. I'm sure that this is not a fix for everyone but it is worth mentioning
Old Sep 17, 2005 | 08:03 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Well I'll be darned. I've lived with this for 3 years. Should have adjusted those bumpers 3 years ago! Thanks for the tip.
Old Sep 17, 2005 | 08:08 PM
NOSjohn's Avatar
NOSjohn
Hahaha...it's good when you learn something new everyday!
To Trunklid does not pop-up
