Need help fast!!
Old Sep 15, 2005 | 09:29 AM
z06boz's Avatar
z06boz
Default Need help fast!!
i have a plug and play hid kit 9006 everything plugs up like a champ but when i turn the headlights on they dont come on, we tested the lights and all they work fine on any other 9006 car, i checked the fuses there fine i even changed them to 20's no luck and i cant seem to figure out what will make them work, is there a block or a bypass or something help please.
thanx a million in advace.
Old Sep 15, 2005 | 09:37 AM
Jstyle's Avatar
Jstyle
Do your stock lights work?
Old Sep 15, 2005 | 09:39 AM
JR_VETTE's Avatar
JR_VETTE
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Do a search on here. I vaguely remember seeing something about some HID kits not being compatible. That's all I remember. BRB...I'll see if I can find it.
Edit - I might have been thinking about the door problem :
http://forums.corvetteforum.com/showthread.php?t=950355
This might be helpful also :
http://forums.corvetteforum.com/show....php?t=1143557
Old Sep 15, 2005 | 09:55 AM
z06boz's Avatar
z06boz
yea when i plug the stock lights in they work when i plug the hids in they dont, is there some kinda block or current or something?? but the weird thing is the kit works on two of my buddys cars that are 9006, not vettes.
Old Sep 15, 2005 | 10:05 AM
z06boz's Avatar
z06boz
i was readin what that guy said about reversing the plug what does he mean heres his quote "Unplug the factory harness from the HID bulb harness reverse it and plug again"
Old Sep 15, 2005 | 04:16 PM
DangerousMind's Avatar
DangerousMind
I had to reverse the wiring on my BMW before the lights would work. Good luck. There is a one way plug that you need to file or cut a tab off in order to make it work. - Colin
To Need help fast!!
