A/C Smell
On the drivers side of the windshield Cowl there is a shallow well that houses your wiper motor and the wiper motor controler. There are three rubber UTTER drains that get clogged up. The leaves, acrons, plant matter and GOOK really can smel bad not to mention that the water that doesnt drain out can cause the wiper motor to fail.
Here are some pictures of the drains:
HERE IS A SHOT OF THE ENTIRE WELL AND UTTERS!!!
WHEN YOU CLEAN OUT THE UDDERS, THIS IS WHAT YOU WILL FIND!!
Man does it STINK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :eek:
Milk out the crap and flush the well out with a hose. Recheck for debreis.
There is one other thing that can cause a AC smell and that is a clogged AC air box drain. When the AC or Deforst is on, condensation will form on the evaporator. It needs to drain out and the evap coil need to dry off. If the drain is clogged, the condensation can not drain out and stuff will start to grow in the air box!
Here is the rubber drain tube:
The crinped end will clog up with slime. Recommend trimming the crimp off!
Rubber tube on the fire wall drictly behind the passengers side cylinder head. (engine removed for clairity!! :eek: )
Hope that helps
Let me know what you find in the drains and if that helps with the smell!!! :thumbs:
Bill C
