plug wire ohms check question
Old Sep 15, 2005 | 02:50 PM
AFBombdude's Avatar
AFBombdude
Default plug wire ohms check question
I just checked the resistance on my '03 w/ 14k miles (originals) and my meter read .720 k ohms, then the ones on my '98 w/ 50k miles (originals) and they read .306 k ohms. I thought you wanted less resistance? What gives? Electricity gurus please help.
Old Sep 15, 2005 | 04:42 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The GM spec is 250-750 Ohms end to end. If you see any corrosion in or on the terminals inside the boots, cuts, nicks or burns on the insulation or boots, it time to change the wires. If you move the wires around and the resistance readings vary alot, the wire inside the SP wire is probably. 750 ohms is the far end of the scale but probably good. If yo start to see readings in the 10, 20 K ohm or in the MEG ohm range, the wires ar toast!
Bill Curlee
Old Sep 15, 2005 | 05:16 PM
AFBombdude's Avatar
AFBombdude
Bill Curlee
My older wires have less resistance. Shouldn't it be the other way around? New wires=less resistance, Old wires=more resistance?
Old Sep 15, 2005 | 09:23 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
As long as their in spec,,,I wouldnt be too concerned about it! Wires will not make HP. They only way wires will improve an engins performance is if the old wires were BAD to begin with and were breaking down under load.
Bill C
To plug wire ohms check question
