Exhaust install question
Old Sep 16, 2005 | 06:46 PM
LS7's Avatar
LS7
Default Exhaust install question
I'm planning on installing the Corsa Touring Tiger Shark Exhaust. Is it worth it to install the X pipe at the same time, and if so are the O2 Sensors located in the X pipe?
If they are, is it difficult to remove them and install them into the new X Pipe and how do they come out?
Old Sep 16, 2005 | 06:55 PM
T.J.'s Avatar
T.J.
If you can do it all at once, go ahead. If not you can always come back and do it later. The rear O2 sensors are located in your cats and not the x-pipe.
Old Sep 16, 2005 | 08:16 PM
JON CONA's Avatar
JON CONA
Default X-pipe Install
The Addition Of A X-pipe Will Make Your Corsa Sys. Run A Little Quieter & Get Rid Of The Burble In The Exhaust Note. It Should Also Add A Few Ft.lbs. Of Torque. Enjoy.....jc
To Exhaust install question
