Clutch
Old Sep 17, 2005 | 09:27 AM
Classical Glass's Avatar
Classical Glass
Default Clutch
I have a 2002 6 sp and I have been reading about a clutch adjustment that is performed under the car. They say to remove the lower inspection cover, have a helper push down on the clutch pedal.While under the car with a couple of long screwdrivers the clutch disk is moved ccw.When compleat you're helper lets up on the clutch and it locks in place.My question is what will this do if anything and why didn't GM perform this to begin with?My car is apart now and I'm not sure if I want to do this adjustment or not.My clutch engages very high on the travel like most Vets and I have always owned older muscle cars I'm used to a lower engagement.And I was woundering if this adjustment will lower the engagement point or not.Thanks for you're time....
Old Sep 17, 2005 | 01:15 PM
Operations's Avatar
Operations
