oil pump location
Old Sep 18, 2005 | 04:41 PM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Default oil pump location
Hey everybody, I was just wondering I seen an oil pump on ebay and it looks alot differant than the old oil pumps on the old 350s. Does the LS1 oil pump bolt on the outside of the engine or something? I don't need to replace mine but I was just wondering in case I would have to. Thanks everybody
Old Sep 18, 2005 | 07:16 PM
jers98vet's Avatar
jers98vet
The oil pump is behind the timing chain cover and is driven by the crankshaft. There are some good pix on ls1howto.com.
http://www.ls1howto.com/index.php?ar...3d17efd9f279ec
Jer.
Old Sep 18, 2005 | 08:04 PM
mvvette97's Avatar
mvvette97
Jer.
WOW, thanks man. It doesn't look like it would be that hard
Old Sep 18, 2005 | 08:13 PM
ArKay99's Avatar
ArKay99
No, except you have to remove the steering rack. and to remove the steering rack, you have to remove the radiator. Then you have to pull the balancer and probably replace that with a new one, since they are essentially pressed on and after it is pulled off the inside is stretched. Been there, done that, it is about a full days work with the right tools the first time.
Old Sep 18, 2005 | 08:29 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
You don't need to pull the radiator to get the rack out, but its still a sucky job. I just did mine for the second time, first time I neglected to use a new O-ring. I didn't replace the balancer, but the bolt is a one time only torque to yield part. They are around $3 at a dealer.
Old Sep 18, 2005 | 08:55 PM
mvvette97's Avatar
mvvette97
Yea, I had the rack off a while back to change the balancer. That wasn't much fun.
To oil pump location
