catch can
Old Sep 18, 2005 | 05:06 PM
tiojames's Avatar
tiojames
Default catch can
Got my catch can from E-Bay. $39. Question is-there are two 3/8 hose lines going to the throttle body area. One comes out from under the intake valley and goes into the plastic area between the throttle body and the manifold. The other one comes from the top side of the right hand valve cover and goes to the top of the aluminum throttle body itself. Should I run both of these thru the catch can or just the one from under the intake plenum? The car is an 04. It had 9400 mi. on it when I bought and oil deal said 91% left. Have put over 5000mi. on it and oil says 18% left and is down less than 1/2 qt, so I don't think it is using much oil anyway. Thank you for your input in advance.
Old Sep 18, 2005 | 05:40 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
It goes from the nipple off of the vally pan to the catch can. Then from the catch can to the Intake.
Leave the line that goes from the TB to the valve cover ALONE..
Jeff
Old Sep 18, 2005 | 07:35 PM
tiojames's Avatar
tiojames
Default catch can
Thanks Jeff.
To catch can
