Catch Can Question
Old Sep 19, 2005 | 02:54 PM
VETT2DY4's Avatar
VETT2DY4
Default Catch Can Question
I purchased a Catch Can on Ebay but it did not come with instructions. My question is, Where should the PCV valve go? Should it be between the crankcase and the catch can OR between the catch can and intake?
Old Sep 19, 2005 | 03:10 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
LS1 or LS6??
Old Sep 19, 2005 | 04:50 PM
Dirty Howie's Avatar
Dirty Howie
Originally Posted by AMERICAN_HP
LS1 or LS6??
Tell him quick before his valve disappears like some of us...
Should be getting my AMW can anytime now. Crank line to top of can....bottom line to Intake.
Think I should by a PCV valve and put it in line to the Crank..
DH (PCV-LESS)
Old Sep 19, 2005 | 05:45 PM
frank dupuy's Avatar
frank dupuy
DH (PCV-LESS)
Howie you are in the early stages of PCV intoxication. Vett2dy4 has a 2001 you have a 2004 two different system configurations. I don't think it should matter where the PCV is installed relative to the catch can. Before or after will depend on the location of PCV on the motor. I think keeping catch can in a secure and accessible location for service would be my top priority. Howie you don't need to buy a PCV but you do need to get your car ready in order to guide me around Willow on Sunday,you already missed last Saturday.
Old Sep 19, 2005 | 07:33 PM
Dirty Howie
It was a JOKE Frank....a JOKE: Air must be pretty thin way above those roll hoops
I am WAY ready for Sunday....
DH
Old Sep 20, 2005 | 06:31 AM
VETT2DY4's Avatar
VETT2DY4
It's a LS1........Thanks for the replies.
Old Sep 20, 2005 | 11:15 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
DH (PCV-LESS)
HA HA Funny . I take it you havent called one of our reputable tuners here on the forum and asked them.
I cant beleive your actually gonna make a rude a$$ comment when you actually have NO CLUE as to what your talking about. I dont tell you how to clean my teeth, dont "ACT" like you know what your talking about when it comes to cars.
Old Sep 20, 2005 | 11:21 AM
Hall1836's Avatar
Hall1836
I'm on Long Island have a catch can on 2001 e-mail me your telephone number and I'll walk you thru it hall1836@optonline.net
Old Sep 20, 2005 | 11:22 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
I'm sure you guys already know this as to your expertise in PCV Valves, but actually there IS a location that is most effective with the PCV system. The PCV valve has about a 3" wire connected to it. This wire has a small clip on the end. That clip is attached the the long threaded stud on the top of the block right next to the intake. The reason its secured there is NOT just for stability reasons, but for condensation. According to GM, that wire aids in the reduction of condensation in the PCV system. It also help in very cold climates.
Old Sep 20, 2005 | 03:21 PM
jo8243's Avatar
jo8243
I have a 2004 and I don't have a PCV valve that I can find on the motor (and I've followed the service manual pics... nada). Is that normal? Did they change something in '04 and not update the manual?
Thinking about installing a catch can myself.
Old Sep 20, 2005 | 04:35 PM
frank dupuy
I am not sure what you are saying in your reply. It looks like a excerpt from a GM service bulletin. The original question was where to locate the catch can relative to the PCV. The location of the PCV on the C5 engine varies depending on the year model etc. My opinion would be to mount the catch can in a secure location with easy access for draining etc, before or after the PCV shouldn't matter. If I am wrong on this I stand to be corrected not crucified.
Old Sep 20, 2005 | 04:49 PM
CorvetteSteve's Avatar
CorvetteSteve
Stupid question, but.....I take it this "catch can" is a must do mod. for the long run of the engine! I just bought my 97 a few weeks ago and I'm trying to learn everything I can as fast as I can!!
Old Sep 20, 2005 | 05:25 PM
frank dupuy
In my opinion the catch can on a stock C5 is not a must do mod but probably won't hurt anything if installed properly. Will help keep carbon deposits out of your motor. On a high HP/supercharged or turbo motor it becomes more important also if you plan on tracking your car. Welcome aboard.
Old Sep 20, 2005 | 06:24 PM
Dirty Howie
HEY!!!!!!
I made no rude A$$ comments. I was trying to be humorous and assumed you would reflect on the other thread we were both posting on.
If you read my posts you will see I profess to know nothing. If thats not clear let me say it again. I don't know **** about how engines work. I don't do any work on my car ...... I let professionals do that. I might install this catch can....but will have it checked later.
In the other posts I never questioned your knowledge (read them and you will see). All I ever did was to state flatly that I don't have a valve where you say I should (and I am not alone). I even tried to come up with some plausible expanations in your defense.
This PCV is a curious situation to me. I am trying to learn...and listen/read all comments. If you are offended by anything I said then you have taken it ALL WRONG
If you don't feel like apologizing too me publicly then just send me a box of SEES candy.....
DH
Old Sep 20, 2005 | 07:20 PM
CorvetteSteve
Thank You frank dupuy...
Old Sep 20, 2005 | 08:29 PM
RPO_Z06's Avatar
RPO_Z06
Cruise-In III Veteran
St. Jude Contributor
This will apply to your '01, these are pics of my install.
You can see the PCV is located down close to the vally cover, make sure you have it where its going the right direction, incase you don't know its a big one way valve and only works when its pointed the correct dirrection, open goes toward the catch can.
Old Sep 20, 2005 | 11:49 PM
johnlovescar's Avatar
johnlovescar
What does a "Catch Can" do for you and advantage is ??
To Catch Can Question
Old Sep 21, 2005 | 10:11 AM
H20Vette's Avatar
H20Vette
RPO_Z06, what brand of catch can is that in your pics?
Old Sep 21, 2005 | 11:31 AM
algZO6's Avatar
algZO6
That is the e-bay special. I just got mine in last week under $40 shipped. It is a quality piece.
Old Sep 21, 2005 | 12:22 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
HEY!!!!!!
DH
Sorry,
4 days worth of being sick with the flu AND taking care of a 3 year old that is sick with the flu can wear on a persons nerves.
See's candy in the mail...
