lowering bolt size
Old Sep 21, 2005 | 12:27 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Default lowering bolt size
I'm going to get some longer bolts for the rear and I have read to use 9/16 or 1/2 bolts. Would the 9/16 be to big to go through the holes? Just wondering wich would be the best size. Thanks
Old Sep 21, 2005 | 01:32 PM
2kbluestreak's Avatar
2kbluestreak
9/16" bolts are very hard to find, especially if you want long ones like 7 inches, so you'll do OK with 1/2"-13 bolts. I believe the stock bolts are threaded 14-2 mm (.551"-.08"), but the bolt shaft is necked down to .500". Soft bolts would probably work as I cannot see how they could be loaded enough to bend or break, but since there are only two, spend the extra couple dollars and buy grade 8. Don't forget to buy two Nylon insert locknuts, they only come in 1/2-13.
Old Sep 21, 2005 | 01:41 PM
DPG's Avatar
DPG
St. Jude Donor '06
Where have you guys found the grade 8 bolts. They are so hard to find other than in the vendors at the "corvette tax" price.
Dave
Old Sep 21, 2005 | 02:36 PM
ICaughtVetteFever's Avatar
ICaughtVetteFever
Old Sep 21, 2005 | 03:03 PM
Riggs's Avatar
Riggs
Fastenal.com, or just hit one of their local stores...
Old Sep 21, 2005 | 04:00 PM
mvvette97's Avatar
mvvette97
I just got some 9/16 bolts a little bit ago. I've got mine on but I'm going to take it to a level place to do some adjustments. Oh I found these at John Deere Impliment. I will agree, They are HARD to find.
Old Sep 21, 2005 | 04:20 PM
sprinter's Avatar
sprinter
I lowered mine on the stock bolts with cut bushings. Had plenty of thread and lowered as far as I wanted. Personally, I think longer bolts are a waste of time. The cut bushes will also tighten up the suspension.
Old Sep 21, 2005 | 05:56 PM
Chicago's Avatar
Chicago
St. Jude Donor '15
Dave
There are Fastenal stores all over the suburbs. I got mine in Hillside (some stores may not have them in stock, just call around.) I did, however, have to buy a whole bag of nylock nuts and a whole bag of washers. Check elsewhere for those items. The bolts are around 4 bucks each. I've seen this lowering "kit" on ebay for 50 bucks! Unreal.
Old Sep 22, 2005 | 10:06 AM
DPG's Avatar
DPG
St. Jude Donor '06
Sounds good, thanks. Guess it's back to the phone for me. Oh and if you try and call Home Depot. They didn't even know what a grade 8 bolt was. I hung up right away.
Old Sep 22, 2005 | 11:05 AM
Chicago's Avatar
Chicago
St. Jude Donor '15
The Depots around me only had them up to 4" long. Menards had 6", close but no cigar. Call Fastenal and you'll be all set.
Old Sep 22, 2005 | 12:15 PM
DPG's Avatar
DPG
St. Jude Donor '06
Thanks Chicago!
Dave
Old Sep 22, 2005 | 04:22 PM
MY1STPEWTER's Avatar
MY1STPEWTER
They are quite hard to find. The only place I could even get them ordered was Fastenal. I've had mine ordered for a week now and still not in. None of their stores had the 9/16, or not the ones he pulled up on the computer anyway. He finally found some 14mm that are close to 7 inches.
Old Sep 22, 2005 | 04:49 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
Get 5/8's x 7" bolts w/4 washes and locking nuts ream out your bushings so the 5/8's bolt will fit(spray a little WD-40 on the bushing to slide the bolt through).And you don't have to cut the bushing.I don't think they have to be grade 8 they are a little bigger than stock bolts.I found grade 8 5/8 x 7" bolts,those are hard to find.I got them at SARJO INDUSTRIES,POUGHKEEPSIE,NY(845)454-0070.I think they have any bolt you need.
To lowering bolt size
