MAF Sensor question.
Old Sep 21, 2005 | 01:24 AM
Itza61's Avatar
Itza61
Default MAF Sensor question.
Does anyone know if you should change the MAF sensor after installing a ram air intake? Thanks
Old Sep 21, 2005 | 01:32 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
I guess It's up to you. I have a Granetelli on mine and works fine but I have a forum buddy that got one and it made his car ping kinda bad. I didn't really notice much gain in power but I did on milage. So it's pretty much a $300 guessing game.
Old Sep 21, 2005 | 02:06 AM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
No, do not change your factory air meter.
Charlie
Old Sep 22, 2005 | 12:00 AM
Itza61's Avatar
Itza61
Thanks guys for the quick responses. Think I'll leave well enough alone and not change it. Thanks again for your help.
Old Sep 22, 2005 | 12:17 AM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
Personally I would leave it alone. If you have a ton of crap done and it's a 97-00 I would upgrade to an 85mm. I did. ... If it's an 01+ I'd keep it stock or knock the screen out since it's 85mm. If it's a 02+ Z06, then you alreayd have an 85mm descreened unit..
To MAF Sensor question.
