Rotor prep - Help!!
Old Sep 21, 2005 | 01:44 PM
Halfway's Avatar
Halfway
St. Jude Donor '06
Default Rotor prep - Help!!
Hello,
I just recieved a set of AC Delco slotted/drilled rotors. Since these are not zinc plated, I imagine they will rust. What is the best way to prep these before I put them on my car to keep them looking new for years to come?????? I want to do this right and only once if possible.
Please help me figure out what to do or share what worked for you!
Thanks,
Greg
Old Sep 21, 2005 | 04:03 PM
DirteeDave's Avatar
DirteeDave
At minimum, I would apply "clear" to the hats. If you want to paint the hats a color that's fine but I would also clear them as a last step.
Old Sep 21, 2005 | 07:27 PM
SGT. PYLE's Avatar
SGT. PYLE
Use a wire brush to ruff up the hats and then use some VHT header paint.
Old Sep 21, 2005 | 07:31 PM
Ron71's Avatar
Ron71
I taped off the brake surface of my rotors and then painted the hub and the outside of the rotor with some high temperature caliper/rotor paint that I bought at Autozone. There are a couple different colors to choose from and so far it is holding up great.
Old Sep 22, 2005 | 09:18 AM
Halfway's Avatar
Halfway
St. Jude Donor '06
Doing this now!
Great info Guys!!!!
To Rotor prep - Help!!
