Lets talk heads
Old Sep 22, 2005 | 08:06 PM
2mcvett's Avatar
2mcvett
427 CID Futral cam
Intake; lift .610 duration 239
Exhaust; lift .619 duration 243
On a 114 lobe sep.
Heads AFR blanks ported by TEA
Flow# lift intake exhaust
0.100 72.4 50.1
0.200 154.3 126.4
0.300 224.9 198.3
0.400 275.3 250.0
0.500 319.5 280.1
0.550 336.8 287.0
0.600 346.2 288.9
0.700 349.4 292.3
Dyno# 529 RWHP @ 6000 RPM 522 TORQUE @ 4600 RPM
Power band: 500 RWHP @ 5200 RPM
520 RWHP @ 6500 RPM
500 TORQUE @ 4000 RPM
423 TORQUE @ 6500 RPM
FLP 1 3/4 headers to 2 1/2 X pipe B&B tri flows
Fast 90 with NW 90 TB
Best part 20 MPG and driven daily ( very well mannered ) wife drives it to work once in a while, 80 mile round trip.Gets 2 MPG more than her
Plymouth van.
Just got kooks 1 7/8 with 3" X-Pipe should be worth about 25 RWHP
Old Sep 22, 2005 | 10:53 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Originally Posted by Phil97SVT
4 words:
ET Performance 11degree
I hope to soon find out. I am having a forged 402ci LS2-based stroker built with ETP 11 degree 215s, and a 228/232 .581/.588 114+4 via Comp 1.75 rollers (effective lift = .598/.605).
Here are the numbers for this head:
Code:
Valve Lift  Intake  Exhaust
  .100"       74      57
  .200"      152     106
  .300"      219     150
  .400"      266     190
  .500"      301     204
  .550"      312     208
  .600"      320     211
  .650"      323     214
It won't be the biggest or baddest, but it should be fun on the street.
Old Sep 23, 2005 | 01:02 AM
Tony Mamo @ AFR's Avatar
0Tony Mamo @ AFR
Former Vendor
Originally Posted by ecudooberhead
I can find used AFR's all day long for $2K... plus I already have upgraded valve springs in my LS1 heads I'll use. I am not terribly concerned with pricing, I would just like to keep it around $2K, but I want essentially the best I can get in the price range. I have had a lot of different opinions though, a lot seem to think AFR is the way to go though
Randy
Hello Randy....
You might want to take a look at this thread....
http://www1.ls1tech.com/forums/showt...t=317323<br />
Very informative and shows a very large cross section of heads from all over the country. The beauty is that all the info is taken from the same testing equipment. Look how efficient even the 205's are in most company that have 30-40 cc's of additional volume advantage....thats beyond huge. The numbers speak for themselves. Call me at AFR if you get a chance....Would love to speak with you about your project goals....I'm confident the AFR's will deliver and would like the opportunity to discuss their design benefits with you.
Regards,
Tony M.
(818)890-0616 Ext. 109
