I am looking into getting new heads for my car, and want the best I can do for up to around $2K. I dont know a lot on the topic, but I had TEA heads recommended to me, saying they are the best out of the box (even when compared to AFR heads) - I am leaning towards the stage 3 5.3L heads since they flow the best, and I only want to do this once. Here's their flow data
If I was going to spend $2000 on heads, then I would chose the AFR's if it was up to me. 205's unless you are running bigger cubic inches. If you want to save some $$$, DART is about to introduce a LS1 head. It looks to flow a little less that the AFR/s but I heard that they will be about $1100-$1200 a set. I have seen Dyno sheets of the AFR/s and they don't lose any bottom end torque. Remember, Flow isn't everything. Velocity is very important. I remember a person saying one time...... you can't drag race a flow bench.
I understand what you're saying. But after talking with Jeff Creech (a popular tuner here in NC who specializes in LS1's) he says AFR heads aren't as good out of the box as TEA heads. However, he said if I was to get AFR heads and do additional work to them, then that would be a better route. I would like to make close to 450rwhp with the heads I go with, with the mods listed in my signature
You cant realize the true performance of these heads except on the street. flow sheets are good to make paper planes out of them. No one has come close to producing the port velocitylike the 205s
TEA is one of the best out there. If you check their dyno # you'll see. I did the best of both worlds. I went with the AFR blanks ported by TEA. It is a big inch motor but what impressed me was at 2000 rpm in overdrive the car has great manners, but the heads flow 349 @ .700 on the intake. Car made 530 RWH with mild cam and small headers.
Would you recommend AFR's over the LPE Stage 2 heads? What kind of power did you achieve with yoursetup?
Randy
I peaked at 412rwhp, 385rwt. but its not about the peak, its all about the power under the entire curve. this is with a tiny cam 220/220 .581@115 (mti stealth cam) You dont need a big cam to make these heads produce good power. do some research first, then pair it up with a good cam. you wont be sorry!
No one has come close to producing the port velocity like the 205s
This is one thing often overlooked. Flow data alone won't characterize the heads in my opinion, as you can get good flow data with bigger ports, which also slows velocity. Tony Mamo provided some data recently on LS1Tech on head flow from which you could compare flow velocity. He didn't identify the competitors heads, but there were few that matched the AFR 205's.
I can find used AFR's all day long for $2K... plus I already have upgraded valve springs in my LS1 heads I'll use. I am not terribly concerned with pricing, I would just like to keep it around $2K, but I want essentially the best I can get in the price range. I have had a lot of different opinions though, a lot seem to think AFR is the way to go though
My AFR's, with our porting and polishing, outperformed my old ls6 hand ported heads. I spent more on my old heads. The AFR's were only a few months from being released at the time.
Interesting...... what is the lift of your cam?? Do you have a .700 lift cam to utilize the flow? How's the flow under the curve? Is your car a d.d.? Please describe your engine combo. No specs mean diddly.
