Weird Electical Issue
Old Sep 23, 2005 | 10:38 AM
dbros9's Avatar
dbros9
Default Weird Electical Issue
Was driving 99 very last night - allof a sudden the the dash light flickers, the radio volume went down and then back up and the DIC kept showing service Ascitve handling - service ABS - service traction system. also the idiot light for active handling and ABS went on.
It was getting dark so i turned the lights on all the gauged - speedo - tack etc went to the far right - radio went dead. I turned off lights and they went back to normal. Got car home - tried to put lights on again and they would not pop up. Turned the car off - restarted car and all was fine. one other thing - display for radio and temp control flicker slightly most og the time -
Any clue what is going on here??
Thanks...
Old Sep 23, 2005 | 10:58 AM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
Originally Posted by dbros9
Was driving 99 very last night - all of a sudden the the dash light flickers, the radio volume went down and then back up and the DIC kept showing service Active handling - service ABS - service traction system. also the idiot light for active handling and ABS went on.
It was getting dark so I turned the lights on all the gauges - speedo - tac etc went to the far right - radio went dead. I turned off lights and they went back to normal. Got car home - tried to put lights on again and they would not pop up. Turned the car off - restarted car and all was fine. one other thing - display for radio and temp control flicker slightly most of the time -
Thanks...
How is you battery
Old Sep 23, 2005 | 11:08 AM
dbros9's Avatar
dbros9
Default battery
battery is new -
Old Sep 23, 2005 | 11:52 AM
dbros9's Avatar
dbros9
Default battery
the new battery is not GM - Costco I think - hopefully thats not it...
Old Sep 23, 2005 | 12:19 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Sounds like a LOOSE connection. Start at the battery terminals. Remove them, clean with a wire brush, spray them out with WD-40 and TORQUE them on to the battery with a torque wrench to 11 ft/lbs.
The next place to look will be the battery cables at the starter and engine block.
There are also B+ battery connections on each fuse box. Check them for tightness. REMEMBER!!! They are ALWAYS HOT!!!!! Be careful.
Old Sep 23, 2005 | 03:47 PM
konish's Avatar
konish
ignition switch?
R/
Dustin
To Weird Electical Issue
