Ac
Old Sep 24, 2005 | 09:24 PM
oaks99's Avatar
oaks99
Default Ac
i know i seen a thread some where about ac blowing cooler air on passenger side than drivers . can someone tell me where to look. thanks
Old Sep 24, 2005 | 10:25 PM
David426's Avatar
David426
Use the Search on the Tech Forum. Seems to be a fairly common problem from what I have read.
Old Sep 24, 2005 | 10:26 PM
DngrZne's Avatar
DngrZne
I don't know where to point you, but I am experiencing the same thing right now. I believe that it is an indication that the A/C system is low on refrigerant though, if that helps.
Chris
Old Sep 24, 2005 | 11:04 PM
oaks99's Avatar
oaks99
yeah they did the dye test on mine and added more coolant about june or july i've never had a car do this and its to have to go back out an fork out more money to them
Old Sep 29, 2005 | 05:33 PM
Der Flieger's Avatar
Der Flieger
Default AC Problems
Check your history codes on the DIC. Reset them and it should start working normally.
To Ac
