How reliable are headers?
Old Sep 28, 2005 | 11:24 PM
KGB6's Avatar
KGB6
Default How reliable are headers?
Please share with me your experiences with headers. I am considering having them installed on my C6 but am concerned about reliability problems such as leaks, rust, etc..
Old Sep 28, 2005 | 11:26 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
the coated ones will last as long as any OEM ones will...definetly not something to worry about
Old Sep 29, 2005 | 07:44 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
after teh install you should check to make sure everything is tight otherwise you will see no issues with aftermarket headers...
Old Sep 29, 2005 | 08:59 AM
byte_me's Avatar
byte_me
Been running Stainless Shorties on my Coupe for several months now- including a 1200 mile round trip with no issues what so ever...in fact, the car runs A LOT cooler now...plus the added HP increase. I have B&B Stainless T304 and not coated...Stainless should last forever!
I say go for them- the headers out today are really well made....and all Stainless!
Old Sep 29, 2005 | 09:11 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
w/ the above, BUT..
Some manufactures use thin-wall tubing to save weight.. We (the CF) have seen the occasional cracks / breaking of welds.. I wouldn't expect a super-light weight aftermarket system to go 200K miles (like the stock exhaust would), but I wouldn't allow that to deter my purchase.
Old Sep 29, 2005 | 10:27 AM
nwdanner's Avatar
nwdanner
To ensure longevity, whatever you buy, make sure it's 100% stainless steel. I bought the LGM setup and I couldn't be happier!
Old Sep 29, 2005 | 10:59 AM
Byter's Avatar
Byter
I have had no problems with leaks, so I'd say they are very reliable. However, they will transmit some valvetrain noise that you normally don't hear with the cast iron exhaust manifolds.
Old Sep 29, 2005 | 11:02 AM
Roofless's Avatar
Roofless
St. Jude Donor '11,'13
If you buy a good set of headers and they are installed properly, you should have no problem and they will porobly out last the car/you
Old Sep 29, 2005 | 11:55 AM
MGorman's Avatar
MGorman
Definitely go with stainless steel headers.
I have the TPIS coated headers and while I am pleased with the performance, after about 2 ½ years and 10,000 miles of use they are starting to rust terribly.
Old Sep 29, 2005 | 12:00 PM
Ken1234's Avatar
Ken1234
Not to steal the post, but are the much louder? I have a vert.
Old Sep 29, 2005 | 12:54 PM
byte_me's Avatar
byte_me
Depends on what else you have done...mainly cat back...I put a Z06 catback on my 97 with the shorty headers and the interior sound did go up...probably twice what it sounded like stock..however; at speed the noise from the run flats is louder! the car has a nice deep purr to it now...I would venture to say LT's would produce more sound, but if you were consertive with a catback (and were worried about drone) a stock or Z06 catback would be fine. Now if you have heads and a cam package...be prepared for some sound!
Old Sep 29, 2005 | 01:11 PM
simpleman68's Avatar
simpleman68
I would venture to say LT's would produce more sound, but if you were consertive with a catback (and were worried about drone) a stock or Z06 catback would be fine. Now if you have heads and a cam package...be prepared for some sound! [/QUOTE]
Yup! Exactly what he said
Scott
Old Sep 29, 2005 | 01:42 PM
Black 00 Coup's Avatar
Black 00 Coup
get the LGM set up
Old Sep 29, 2005 | 04:07 PM
DPG's Avatar
DPG
St. Jude Donor '06
No matter what you get, get them ceramic coated. If the ones you buy dont come coated or dont have an option to coat. Go find a place that will do it. Its fairly cheap. Around $280 i think for a set of Longtube headers.
Old Sep 29, 2005 | 05:36 PM
boosted_z06's Avatar
boosted_z06
No I would not coat them if they are stainless steel for it transmits heat out on it own and when you coat them you increase the chances that welds will crack.
The cheapo mild steel ones should be coated on outside only.
To How reliable are headers?
