98 pcm pinout
Connector Part Information
PCM Connector C1 (Red)
80 Pin Connector
Pin
Wire Color
Circuit No.
Function
1-3
Not Used
4
BRN/WHT
633
Camshaft Position Sensor Signal
5-6
Not Used
7
YEL
400
VSS Signal High
8
Not Used
9
PNK/BLK
1746
Injector #3 Control
10-11
Not Used
12
LT BLU/BLK
844
Injector #4 Control
13
PPL/WHT
2122
Injector #2 Control
14
DK GRN
59
A/C Status
15
BLK/WHT
845
Injector #5 Control
16-17
Not Used
18
YEL/BLK
846
Injector #6 Control
19-20
Not Used
21
PPL
719
IAT Sensor Ground
22
DK BLU
1225
Transmission Range Signal B
23
LT GRN/BLK
1745
Injector #2 Control
24
BLK/WHT
1704
Sensor Ground Jumper
25
PNK
1224
Transmission Range Signal A
26
BLK/WHT
771
PRND A
27
RED/BLK
877
Injector #7 Control
28-29
Not Used
30
DK BLU/WHT
449
Real Time Damping (W/F45)
31
DK BLU/WHT
878
Injector #8 Control
32
WHT
776
PRND P
33
BLK
1744
Injector #1 Control
34
GRY or WHT
587 or 687
2nd and 3rd gear Block out Solenoid (M/T) or 3-2 Shift Solenoid (A/T)
35
LT GRN
1222
Shift Solenoid A
36
Not Used
37
BRN/WHT
419
MIL Control
38
Not Used
39
DK GRN/WHT
459
A/C Clutch Relay Control
40
WHT or YEL/BLK
375 or 1223
1 to 4 Upshift Lamp Control (M/T) or Shift Solenoid B (A/T)
41
PNK/WHT
1101
PCM Chassis Pitch Output Circuit
42
LT GRN
1652
Reverse Inhibit Solenoid Control
43
DK/GRN
335
Cooling Fan Relay #1 Control
44
DK BLU/WHT
1869
Crankshaft Position Sensor Signal
45
DK GRN/WHT
428
EVAP Canister Purge Valve Control
46
ORN/BLK
463
Desired Torque
47
DK GRN/WHT
762
A/C Request Signal (C60)
48
YEL
492
MAF Signal
49
PPL
2121
Ignition #1 Control
50-51
Not Used
52
RED/WHT
2128
Ignition #8 Control
53
RED
2127
Ignition #7 Control
54
DK GRN/WHT
2126
Ignition #6 Control
55
DK GRN/WHT
817
VSS Output Signal
56
DK GRN
2125
Ignition #5 Control
57
LT BLU/WHT
2124
Ignition #4 Control
58
LT BLU
2123
Ignition #3 Control
59
BRN/WHT
2130
Ignition Control Reference Low Bank 2
60
BRN
2129
Ignition Control Reference Low Bank 1
61
RED
1226
Transmission Range Signal C
62
Not Used
63
BLK
407
A/C Refrigerant Pressure Sensor Ground
64
BLK
452
Engine Oil Pressure Sensor Ground
65
GRY
773
PRND C
66
YEL
772
PRND B
67
Not Used
68
GRY
48
Clutch Switch Signal
69
BRN
1982
EVAP Purge Vacuum Switch Signal
70
Not Used
71
PPL
401
VSS Signal Low
72
BLK/WHT
451C
PCM Ground
73
GRY
847
Extended Travel Brake Switch Signal
74
Not Used
75
GRY
720
Left and Right Fuel Tank Level Sensor Ground
76
BLK/WHT
451H
PCM Ground
77
PPL
420
Cruise/TCC Brake Switch Signal
78-80
Not Used
Blue
PCM Connector C2 (Blue)
80 Pin Connector
Pin
Wire Color
Circuit No.
Function
1
TAN
1671
HO2S Signal Low Bank 2 Sensor 2
2
TAN/WHT
1669
HO2S Signal Low Bank 1 Sensor 2
3
Not Used
4
RED
631
Camshaft Position Sensor B+ Supply
5
TAN
1667
HO2S Signal Low Bank 2 Sensor 1
6
TAN/WHT
1653
HO2S Signal Low Bank 1 Sensor 1
7
RED/BLK
380
A/C Refrigerant Pressure Sensor Signal
8
TAN
472
IAT Sensor Signal
9
Not Used
10
DK BLU
1936
Fuel Level Sensor (Left Tank) Signal
11
GRY
23
Generator F Terminal
12
LT BLU
1937
Fuel Level Sensor (Right Tank) Signal
13
YEL/BLK
1227
Transmission Fluid Temperature Sensor Signal
14
ORN/BLK
1057
Transmission Fluid Temperature Sensor Ground
15-18
Not Used
19
PNK
239
PCM Ignition 1 Feed
20
ORN
340B
PCM Battery Feed
21
BLK/WHT
451F
PCM Ground
22
YEL/BLK
1868
Crankshaft Position Sensor Ground
23
Not Used
24
BLK/WHT
1704
25
BRN
718
ECT Sensor Ground
26
ORN/BLK
469
MAP Sensor Ground
27
Not Used
28
DK BLU
473
Engine Cooling Fan Relay #2 and #3 Control
29
Not Used
30
BRN
436
AIR Pump Relay Control
31
PPL
421
AIR Solenoid Relay Control
32
TAN/BLK
422
TCC Enable Solenoid
33
BRN
418
TCC Control (PWM) Solenoid Control
34
Not Used
35
WHT
121
Engine Speed (Tach) Output Signal
36
LT BLU/WHT
1229
Transmission Fluid Pressure Control Solenoid Control Low
37
DK GRN/WHT
465
Fuel Pump Relay Control
38
Not Used
39
RED/BLK
1228
Transmission Fluid Pressure Control Solenoid Control High
40
TAN/BLK
464
Torque Delivered
41
PPL
1670
HO2S Signal High Bank 2 Sensor 2
42
PPL/WHT
1668
HO2S Signal High Bank 1 Sensor 2
43
Not Used
44
GRY
598
Fuel Level Sensors 5.0 Volt Feed
45
GRY
596
Engine Oil Pressure Sensor 5.0 Volt Reference
46
PPL
1666
HO2S Signal High Bank 2 Sensor 1
47
PPL/WHT
1665
HO2S Signal High Bank 1 Sensor 1
48
LT GRN
432
MAP Sensor Signal
49
YEL
410
ECT Sensor Signal
50-52
Not Used
53
TAN/WHT
331
Engine Oil Pressure Sensor Signal
54-57
Not Used
58
DK GRN
1049
Serial Data Class 2
59
Not Used
60
BLK/WHT
451E
PCM Ground
61
ORN
340C
PCM Battery Feed
62
LT GRN
1867
Crankshaft Position Sensor B+ Supply
63
Not Used
64
GRY
416
MAP Sensor 5.0 Volt Reference
65
Not Used
66
GRY
474
A/C Refrigerant Pressure Sensor 5.0 Volt Reference
67
Not Used
68
LT BLU
1876
Knock Sensor (KS) Rear
69
DK BLU
496
Knock Sensor (KS) Front
70
PNK/BLK
632
Camshaft Position Sensor Ground
71
TAN
800
TAC Module Serial Data
72
ORN/BLK
1061
73-75
Not Used
76
BRN
1174
Oil Level Sensor Signal
77
RED
225
Generator L Terminal
78-80
Not Used
