DIC question...
Old Sep 25, 2005 | 11:10 PM
Boomah's Avatar
Boomah
Default DIC question...
Aloha gents,
Hope someone here can help with this… I’m sure it’s been covered before but I couldn’t track down the good gouge & may have the terminology wrong.
My DIC isn’t displaying tire pressure at all on my ‘03 Z06. I’m pretty sure I’m on the correct page; oil temp, pressure, etc. are all easily accessed, just no tire pressure. The car originally had aftermarket rims but I had them replaced with stock examples. Any chance that screwed things up… Can you turn off the DIC tire display & if so, can you turn it back on again? I’m hoping this is an easy fix & simply an “operator head-space & timing” issue
TIA & Mahalo
Mark
Old Sep 25, 2005 | 11:48 PM
Snidley's Avatar
Snidley
Z06's don't have tire pressure monitors. If your wheels have the senders, I understand that the dealers can turn the system on.
Old Sep 25, 2005 | 11:54 PM
Boomah's Avatar
Boomah
Well that explains it... found it in the manual as well, probably should have check it out first. Chock another up to brain-lag
Thanks for setting me straight
Mahalo,
Mark
To DIC question...
