Someone please help me with a constantly popping up code!
Old Sep 26, 2005 | 06:42 PM
Big Red Machine's Avatar
Big Red Machine
Default Someone please help me with a constantly popping up code!
I keep getting code P0171 H ,(Too Lean), fairly regularlly, about 20 times just recently on a round trip from Or. to Calif. & I then erace the code right away. This code will pop up sometimes at a constant speed of 35, sometimes on excessive aceleration, & occasionally on a set speed of 75 on Cruise Control. Most of the time it was a "History" code, but a few times it had both "History & Current" next to it. Only twice did P0174, (Too Rich), pop up & it was a 'History' code. If it's a "History" code, & I keep eracing it, why does it keep coming back? Should I just live with the aggravation of having to erace the code on a fairly regular basis, or is their something I can do on my DTC?
Old Sep 26, 2005 | 08:07 PM
ArKay99's Avatar
ArKay99
It's your computer trying to tell you something is wrong. Either out of cal or broken. In your case it's probably 'out of cal'. Did you recently add a mod like a cold air intake, or a set of headers? If not, I would suspect you are getting air behind the MAF. Either the airbridge clamps are loose or the throttle body could be loose, etc. Sounds like a possible air leak somewhere. Also, the MAF could be dirty.
