Rake Measurement
Old Sep 29, 2005 | 10:37 PM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
Default Rake Measurement
Does anyone know the official locations to measure the rake on the car?
Old Sep 30, 2005 | 12:52 AM
Dirty Howie's Avatar
Dirty Howie
This sounds like a job for the DH tape measure.........
DH
Old Sep 30, 2005 | 09:37 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
You need to measure to reference points that are unaffected by the suspension (i.e., measuring from ground to top of wheel well is n/g). The only place I know of where this would be true is the jacking puck locations - they are directly beneath a common, straight piece of metal (the frame).
Old Sep 30, 2005 | 10:58 AM
FRISKY's Avatar
FRISKY
Cruise-In III Veteran
The answer to your question is the lower A-arms, but that spot is very hard to use without special measuring tools. Most people I know use the metal areas of the frame next the jacking puck holes.
About 1/2-inch difference between the front and rear is a common setting.
Old Sep 30, 2005 | 11:05 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
The manual tells you to measure at the frame as stated above as I remember.
Old Sep 30, 2005 | 12:01 PM
dmtnt's Avatar
dmtnt
St. Jude Donor '03-'05-'06 & '12
I did a lot of research on this. The definitive answer is that there is supposed to be 5mm of rake measured in front of the front jacking puck hole to behind the rear jacking puck hole.
Old Sep 30, 2005 | 08:46 PM
Threed's Avatar
Threed
Thank's to all. That is exactly what I am looking for.
Old Sep 30, 2005 | 11:47 PM
roSSco's Avatar
roSSco
Wow 5mm is not a lot!
Old Oct 1, 2005 | 11:33 PM
dmtnt's Avatar
dmtnt
Remember that's at the frame rails. That translates into about 1/2" difference when measuring from the ground to the top of the wheel wells.
Old Oct 2, 2005 | 07:22 PM
IM QUIKR's Avatar
IM QUIKR
5mm is roughly 0.20" If you get somewhere between 1/4 and 1/2 inch front to back difference you'll be fine. Actually you may get a little more down force at speed which would be a good thing. I just swapped my base springs for Z51 and reset the rake at 1/3" diff front to back. After a week of driving I'll re-measure and if it holds, I'll be back in for a final alignment.
Old Oct 2, 2005 | 08:02 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
I use the location at the frame jacking points as well as it is much easier than the proper spot on the a-arms. I also try to get 1/4-1/2" to help minimize high speed lift.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Oct 2, 2005 | 09:41 PM
Threed's Avatar
Threed
Thanks again to all who responded.
Old Oct 2, 2005 | 10:03 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
How is the frame unaffected by the suspension?
Old Nov 17, 2005 | 09:44 AM
IM QUIKR's Avatar
IM QUIKR
Originally posted by c5d
Tools Required
J 42854 Trim Height Measurement Gauge
Adjustment
When adjusting rear Trim Height the opposite side Trim Height will be affected.
Vehicle on alignment rack.
Set proper tire air pressure.
Manually lift rear end up approx. 38 mm (1.5").
Gently release & let settle (joust) 3 times.
Measure distance (J 42854) between lowest point of the L/R ball joint (2) and the center of the front of the forward rear lower control arm bushing mounting bolt (1).
Push rear end down approx. 38 mm (1.5').
Measure distance (J 42854) between lowest point of the R/R ball joint (2) and the center of the front of the forward rear lower control arm bushing mounting bolt (1).
Meausre Left and Right sides of vehicle.
True D height is the average of the high and low measurements.
Loosen nut at top of spring bolt.
Adjust D Trim Height by turning the spring bolt (1 turn = 2 mm (5/64").
Jounce 3 times and re-measure.
Tighten spring bolt to 37 ft. lbs.
Measure front spring adjuster bolt gaps (1).
Do NOT exceed maximum (5 mm) difference between right and left rear spring stud heights.
Spec: Front Spring Adjuster Bolt Gap: 18 to 40 mm
J Trim Height
152 mm (5.98 in)
145.6-158.4 mm
5.73-6.24 in
K Trim Height
152 mm (5.98 in)
145.6-158.4 mm
5.73-6.24 in
[CSM, 1997, 3-73]
C'ya
D
What/where are the J & K Trim Heights????
These are the points that deterimine the proper rake of the car in the manual.
To Rake Measurement
