Power Ducts ?
Old Oct 2, 2005 | 08:52 PM
jparr's Avatar
jparr
CI 7-8-9-10 Veteran
St. Jude Donor '08
Default Power Ducts ?
are power ducts worth the money ? and what are the pros and cons of haven one ? will a power duct and and air intake make make a gain in hp working together or ??? need soem input thanks jay
Old Oct 2, 2005 | 08:54 PM
jparr's Avatar
jparr
CI 7-8-9-10 Veteran
St. Jude Donor '08
Originally Posted by jparr
are power ducts worth the money ? and what are the pros and cons of haven one ? will a power duct and and air intake make a gain in hp working together or ??? need some input thanks jay
Old Oct 2, 2005 | 09:16 PM
SGT. PYLE's Avatar
SGT. PYLE
Powerduct = appearance mod only, no HP. IMO deffinately not worth the money.
Old Oct 2, 2005 | 09:31 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
If you are referring to those coupler things between the air bridge and intake, probably not. With each generation of Corvette, vendors go out of thier way to create mods that your average Joe can install quickly and painlessly with basic hand tools. Many rush right out and buy them to get all sorts of (claimed) horsepower. While there may be some increase in power or efficiency, its so small that its probably equal to you driving with a 1/4 tank of gas since your power to weight ratio is better.
Old Oct 2, 2005 | 10:33 PM
hp_therapy's Avatar
hp_therapy
My .02 is that unless you are going to open the airflow with a aftermarket intake (blackwing, k&n...ect). And, get a custom tune done to take advantage of the increased flow. And maybe go to headers.... and...and...and... The increased diameter of the air bridge will not help much. Again... my .02
With that said I have a high flow air bridge, for the looks. But I also went the aftermarket route.
Old Oct 3, 2005 | 09:29 AM
Mike04's Avatar
Mike04
Get it for the looks not HP increase.
Old Oct 3, 2005 | 02:32 PM
Lancer033's Avatar
Lancer033
If you've got a 427 sucking in a major amount of air and have already done all of the other intake/exhaust mods, then you might get 2/3hp out of it somewhere in the power curve
To Power Ducts ?
