installing a LS6 cam in a LS1
Old Oct 2, 2005 | 09:52 PM
vettes4fun's Avatar
vettes4fun
Default installing a LS6 cam in a LS1
Are the push rods the same, if no which ones should be used. Thunder racing said they are the same, but I don't think so.
Old Oct 2, 2005 | 11:38 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Assuming a bone-stock LS1 block and heads, and a stock LS6 camshaft, then go with 7.425" PR's, period end.
The PR's in both motors are the same, but the length of the valves are not. The longer PR's correct for the smaller base circle of the LS6 cam.
Old Oct 3, 2005 | 01:30 AM
NSTG8R's Avatar
NSTG8R
if you dont mind me asking .. why go through all that for just a z06 cam?
Old Oct 3, 2005 | 01:49 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Old Oct 3, 2005 | 02:55 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Old Oct 3, 2005 | 05:49 AM
Mitch C's Avatar
Mitch C
There are a lot better cams out there.
Old Oct 3, 2005 | 09:56 AM
lost's Avatar
lost
Advantages of the ZO6 cam[1] idles well[2] does not require a tune[3] costs less by $150 average dollars.Reverse all that for maybe 10-15 hp. with another cam choice.Answer to original question, theoretically a 7.425 push rod should be used, in practice the 7.40 works fine as the lifter preload will cover that small difference.Milling the heads or changing head gaskets will generally get you back to a 7.40 length push rod, also. Not all push rods are created equal, Thunder's 7.40 are actually 7.415.The ZO6 does it by using a .20 taller valve to offset most of the .30 smaller base circle.There are dozens , if not more f-bodys out there with ZO6 cams and stock length push rods without any problems.So if you have money to burn change the push rods, but then you defeat the purpose of the ZO6 cam, cheap horsepower!
Old Oct 3, 2005 | 12:27 PM
Mitch C's Avatar
Mitch C
1. More aggressive cams in the 220 to 230 duration range idle very well also.
2. It is true a tune is not a must with the LS6 cam. But you will gain more power and performance if you do get a tune.
3. Depending on the cam selected you will gain more than just 10-15 RWHP over the LS6 cam
Old Oct 3, 2005 | 12:28 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Without the Z06 heads to go with the Z06 cam, you are not going to pick up much with this swap.
That is an awful lot of work for so little gain at the rear wheels....
Good luck.
Old Oct 3, 2005 | 01:59 PM
2ndVette's Avatar
2ndVette
Old Oct 3, 2005 | 02:27 PM
red97vette's Avatar
red97vette
Good luck.
Old Oct 3, 2005 | 04:48 PM
Face's Avatar
Face
Without tuning you'll be lucky to see 15-20hp. Why even bother. If you're going to do it, do it right the first time. Go with something like a 224/224 on a 114, it's a very mellow cam ,and you'll see some decent gains.
Old Oct 3, 2005 | 10:06 PM
vettes4fun's Avatar
vettes4fun
I'm not doing it, I'm just asking for a non member. Scoggins-Dickie sold the stuff to him so ask them. The END
Old Oct 3, 2005 | 10:25 PM
Face's Avatar
Face
Since this attitude won't get you far on this forum, why don't you go ask Scoggins-Dickie instead.
Old Oct 3, 2005 | 10:43 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
vettes4fun, this is a great thread, i'm sure many people don't know about the PR diff and the diff base circle on the 02-04 cams, i had a similar question when i swapped in a 228/232 588/595 on 114lsa into a c6 this past w/e, the stock ls2 cam is the same spec as a 2001 ls6(z06)cam, although the base circle on that one year is the same as the ls1's; thanks dan and lost for the tech info
the next reply is directed toward face
vettes4fun's Avatar
vettes4fun
The way I see it you are the one with a attitude. I asked to find out for a friend. Not for you to lecture about doing it right the first time. All I was doing was getting peoples opinion on the push rod size because Scoggins said they where the same, I tought they were wrong and wanted some advise from you guys. Some member helped, but a few were A$$. Thanks to those you helped.
Old Oct 3, 2005 | 10:54 PM
new vetter's Avatar
new vetter
I put a z06 cam in my bone stock 99 coupe with 3.42 gears. 315 rwhp/315 rwt with tune.
To installing a LS6 cam in a LS1
Old Oct 3, 2005 | 11:03 PM
NSTG8R's Avatar
NSTG8R
hey it's an open forum and i asked a simple question if you dont like .. stick it in your ear.
cant tell people anything anyways .. you're right .. you've always been right and willa lways . . .forget it.
Old Oct 3, 2005 | 11:05 PM
0EG@EnglandGreen
Supporting Tuner
I totally agree with Face. Signing out of this thread - pointless helping anyone with this kind of rude and nasty attitude.
Old Oct 3, 2005 | 11:28 PM
vettes4fun's Avatar
vettes4fun
