Tire pressure
Old Oct 3, 2005 | 02:35 PM
babalu95's Avatar
babalu95
Default Tire pressure
What kind of tire pressure is recommended for Run-flat/EMT's? Currently I'm at 26lbs. Should it be more?
Old Oct 3, 2005 | 02:40 PM
terlox's Avatar
terlox
I usually run 32psi all around.
You'll get a low pressure warning from the DIC if you ever drop as low as 25psi.
Old Oct 3, 2005 | 02:44 PM
MHVette's Avatar
MHVette
@ 25psi or under you will get a warning for low tire pressure. I run about 30-31 psi cold usually. 32-33 psi warm.
Old Oct 3, 2005 | 03:33 PM
Dustie's Avatar
Dustie
Default TPs
The door sticker says "210kpa" so that's good enough for me
30# for those of you that are "metricly challanged".
Old Oct 3, 2005 | 03:35 PM
Groucho's Avatar
Groucho
Good question...
I'm thinking that at lower pressures such as 29 or 30..it may be running on the sidewalls more..would 32 actually ride softer??
Old Oct 3, 2005 | 03:44 PM
jrose7004's Avatar
jrose7004
I run 30 lbs cold all the way around!
Old Oct 3, 2005 | 03:53 PM
landl's Avatar
landl
From: Portland, Oregon . To err is human, to forgive is NOT company policy
30# cold in all 4
Old Oct 3, 2005 | 03:56 PM
edensknight's Avatar
edensknight
30 PSI cold at all four corners. Moreover, I have personally found that this tire pressure also contributes to the highest wearing tire longevity (mileage) per tire set.
Old Oct 3, 2005 | 04:04 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
43,000 miles from a set of EMT's with 3/32 remaining on the fronts and 2/32 on the rears... this is done withHot tire pressure settings... I never let my tires get over 30 psi hot.,.... this means on a hot summer day they are 25/26 cold...Many people subscribe to this thinking...
Tire rack says GY EMT's dont get good mileage... I beg to differ.
I could have taken my first set of EMT's to 45,000 miles.
AS far as the door sticker, I know for a fact that it is a product liability sticker. It has nothing to do with tire life...its there to keep people from using the max tire pressure rating on the side wall.
Running 30 psi cold will guarantee 36/37 psi hot ,when blacktop road surface temperatures can get up to 140F, which makes the tires center high, over pressure , reduces foot print, and causes premature center wear.
Tires are designed to have a specific footprint based on their application.. setting them cold has nothing to do with how they run when they are heated up...
Old Oct 3, 2005 | 04:32 PM
landl's Avatar
landl
very interesting
Old Oct 3, 2005 | 08:36 PM
Dustie's Avatar
Dustie
[AS far as the door sticker, I know for a fact that it is a product liability sticker. It has nothing to do with tire life...its there to keep people from using the max tire pressure rating on the side wall.
Suppose it depends on where you are driving. Never seen my TPs go above 32 when heated up, even on a summer day in Southern Ontario. But I have seen a low TP message on a cool fall morning . Keeping them at 30 seems to work for me.
Old Oct 3, 2005 | 08:39 PM
Dustie's Avatar
Dustie
Default TP's
To Tire pressure
