Magnesium wheel nuts - torque?
Old Oct 4, 2005 | 02:42 PM
Cochemarman's Avatar
Cochemarman
Default Magnesium wheel nuts - torque?
I wonder if anyone knows what torque the wheel nuts should be for magnesium wheels? I have just fitted a set of powerslot rotors and the manual says that the wheel nut torque should be 100 ft/lbs.
As the mag wheels are held on via steel inserts that do not locate directly onto the rotors, I was wondering whether 100 ft/lbs was too much. Certainly they were only on at around 70ft/lbs to begin with.
But as the wheels have been removed several times by dealers and the caliper mounting bolts were nowhere near the recommended torque settings I am at a bit of a loss on this one.
Thanks in advance
Old Oct 5, 2005 | 02:39 AM
Cochemarman
Aw come on - someone must know!
Old Oct 5, 2005 | 07:35 AM
87bob's Avatar
87bob
Veteran: Coast Guard
Go with what the owners manual says. I believe that the size of the wheel stud would dictate the max torque that they can handle. Any more than that you get into a the built in safety factor any less and they can loosen up. The type of wheel should have little effect if any on the max torque you apply. I also bring up my wheels to torque in a series of steps for example 50 then 75 then 100lbs.
Old Oct 5, 2005 | 09:04 AM
MTurnbo's Avatar
MTurnbo
I'm having a set of magnesiums powdercoated right now and plan on torquing to 100 ft. lbs. Better tight than loose. Don't worry the rim can certainly handle 100 ft. lbs.
Old Oct 5, 2005 | 09:43 AM
UstaB-GS549's Avatar
UstaB-GS549
It should be in the owners manual.
It's usually 100 for aluminum and 80 for steel. I suspect it is the difference in the friction between the cone part of the nut and the surface it bears against on the wheel.
Old Oct 5, 2005 | 09:48 AM
jimmie jam's Avatar
jimmie jam
Default 100 lbs
yes, yes , yes !!!! 100 lbs. start at 50, 75 then 100 smakers. just like GM says.
Old Oct 5, 2005 | 06:06 PM
VetteSiNz's Avatar
VetteSiNz
Old Oct 6, 2005 | 02:09 AM
Cochemarman
Thanks chaps for the advice. The only thing is that on the mag wheels there is no point of contact directly between the nut cone and the rotor - there is a 2mm or so gap, about washer sized behind the steel insert and the hub. There is no sign that any washers have ever been there.
I have looked in the owners manual which is in German (for it is from Germany that I got the car) and German is not one of my strong points . . but there is definitely no mention of wheel nut torque anywhere.
So in the absence of any information to the contrary, I'll stick with 100ft/lbs.
TTFN
Old Jun 20, 2010 | 05:08 PM
MorpheusGPR's Avatar
MorpheusGPR
I am getting my powdercoated set put on tomorrow with the tires being switched over off my other rims. I honestly never looked at the bag of lugnuts I got with the rims, they are different then the others? I know they have plastic caps to go over them.
I have the rubber rings for behind the rim, is everyone still using this? The rubber sections that were around where the studs go through the rim are gone, gone when the powdercoating was done.
Old Jun 21, 2010 | 11:02 AM
corvettebob1's Avatar
corvettebob1
You should have 1 ring for each about 4.5-5.0" in dia. that fits in a groove outside the bolt pattern on the inside of the wheel.
Put these in place before mounting the wheels they are there to prevent water from entering behind the wheel and causing galvanic corrosion between the rotor and the wheel.
There are no seals on the studs.
Wheel nut torque is 100 lbft same as the alumnum wheels.
Old Jun 21, 2010 | 11:17 AM
hotwheels57's Avatar
hotwheels57
http://forums.corvetteforum.com/c5-t...ag-wheels.html
Old Jun 21, 2010 | 11:22 AM
VET IT B's Avatar
VET IT B
Mine have been off and on probably 30 X by now. Always at 100 lbs.
Never a problem. Matk
Old Jun 21, 2010 | 11:23 AM
AU N EGL's Avatar
AU N EGL
I use an impact wrench which gets them up to 75-80 then by hand to 100
Old Jun 21, 2010 | 11:34 AM
bumble-z's Avatar
bumble-z
Originally Posted by AU N EGL
100
I like that method!
Old Jun 21, 2010 | 01:02 PM
tramminc's Avatar
tramminc
For 7 years I've done 110lbs, the extra 10 is for piece of mind.
To Magnesium wheel nuts - torque?
