Active Handling Ghosts
Old Oct 5, 2005 | 06:40 PM
South Tex Vette's Avatar
South Tex Vette
Default Active Handling Ghosts
Has anybody had a 99 C5 suddenly jerk to the right or left and the active handling starts blinking. This has occured a couple of times both at full throtle and just cruising along. The last time just sent me across two lanes of traffic??? How to fix if there is a fix, plus how would dealer fix with all of the tuning already done?
Old Oct 5, 2005 | 06:42 PM
User 81424's Avatar
User 81424
You have a bad sensor and need to get it changed out now!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Turn your AH OFF until you get it fixed!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Oct 5, 2005 | 06:45 PM
South Tex Vette
Thanks for the info. When you say a bad sensor, isn't there several sensors that monitor the system?
Old Oct 5, 2005 | 08:03 PM
User 81424's Avatar
User 81424
Yes, my yaw sensor was bad when I had problems like you describe.
Old Oct 16, 2005 | 08:24 PM
StrayCat's Avatar
StrayCat
Default Service Active Handling, brakes locked at speed
C5 crew
Have 2003 AE convert with F55, 6-speed, 3K miles, box stock.
Have had a couple of incidents with "Service Active Handling" message on DIC and "Check Gages" on HUD.
First time was at slow speed just down the street from my house. While coming to a stop, felt pulsing and heard "grinding" noise. Above messages flashed. Next start up cycle, no codes. Took car to dealer. They found no codes.
Second time was at speed on the freeway, 70 mph. Left brake(s) locked up, causing car to dart left. I caught the car from hitting car next to me, and went back home! Again, messages flashed but disappeared after next start up cycle.
Have been checking through old posts on forum and can't tell if there is a consensus as to cause. I see steering wheel sensor, wheel sensor, anti-lock brake sensor, all listed as possible causes.
Does anyone know for sure what's going on? Any TSBs?
I will take my car in to the shop agan tomorrow.
Thanks for your help!
Have
To Active Handling Ghosts
