Headlights dim momenarily
Old Oct 5, 2005 | 08:50 PM
jjcslynn's Avatar
jjcslynn
Default Headlights dim momenarily
Tonight on the way home I noticed my headlights dimming momentarily. I noticed it after I flashed someone (low to high, back to low), then a couple of times later on. It's a 15 minute ride home from work.
I put the DIC on the battery voltage and it was reading 13.1v unless I put my foot on the brake or turn signals. Then it would drop to 12.8 and go back up to 13.1v.
When I pulled into the garage, I put my foot on the brake and the dimmed in concert with the brake lights.
Is this normal? What could be going wrong. I know the previous owner installed a new alternator. I don't know how many miles ago or when it was done. I also have left my European rear lights in, so I have 5 brake lights and 4 separate turn signals. Maybe this is the problem.
Old Oct 6, 2005 | 12:21 AM
RED99's Avatar
RED99
You may have a battery going bad. Take it and have a load test done on it. It can still have voltage and be weak from not enough amperage.
Also if your air-conditioner compressor puts a heavy load on the charging system and can make the lights dim when it kicks on. Did you have yout AC or Defrost on?
Old Oct 6, 2005 | 12:24 AM
billmoore48's Avatar
billmoore48
I've noticed the dimming on my 2001 Coupe. I keep thinking that it's in response to accessory load somewhere but it's hard to pinpoint when everything's on and working fine. Kind of like the lights dimming in my old house when the refrigerator cycles on.
I wonder if it's the alternator cycling on/off or maybe some unknown accessory cycling on/off. Either way, it's mysterious and something for someone like Bill Curlee or Patches to explain. Not a problem - just mysterious.
Good luck...Bill
Old Oct 6, 2005 | 05:43 AM
larrysb's Avatar
larrysb
They just do that.
The voltage regulator in the alternator is slow to react to sudden changes in load, like when you step on the brakes (brake lights come on) or when the AC compressor kicks in (electric clutch).
Other than redesigning the voltage regulator, there's not much you can do about it.
Old Oct 6, 2005 | 05:48 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by larrysb
They just do that.
This has been mentioned a couple of times in the past. Most C-5s seem to do this.
Old Oct 6, 2005 | 06:47 AM
ronwc's Avatar
ronwc
You may want to try cleaning and tightening your battery connections -solved my simular problem -
Old Oct 6, 2005 | 06:20 PM
stingrayl76's Avatar
stingrayl76
Cured my dimming headlight and erratic voltage reading problems also.
Old Oct 6, 2005 | 06:26 PM
stingrayl76
The momentery voltage drop is normal and .3 volts is not much to be concerned about. It's caused by a slight lag time in charging system. Do a search in C5 Tech (current and archives) for dimming head lights and you will find a wealth of info on the subject.
Old Oct 6, 2005 | 06:37 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Yup, it's totally normal. Mine is caused by the air pump coming on and off. I replaced the OE battery with an Optima battery and it helpd quite a bit but, even that did not eliminate it 100%.
Old Oct 6, 2005 | 06:50 PM
LoneStarFRC's Avatar
LoneStarFRC
Pretty common. Nothing to be too concerned about.
Old Oct 7, 2005 | 07:02 PM
jjcslynn's Avatar
jjcslynn
Default Headlights dimming
My battery was tested about 2 months ago (on warranty) and my AC is broken. Drove it yesterday and it didn't seem to do it as much?
Old Oct 7, 2005 | 07:03 PM
jjcslynn's Avatar
jjcslynn
Thanks all!
To Headlights dim momenarily
