Mill Heads or Not?
Old Oct 6, 2005 | 10:21 PM
1stC5weiss's Avatar
1stC5weiss
Default Mill Heads or Not?
I have MTI's Stage 2E heads, should I mill .030" or leave them alone? What approximate HP gain could I expect if I milled the heads? If I mill them, what other changes must I do? I am currently using MTI's G1 cam. Sorry for all the dumb questions, still learning, all this engine stuff is relatively new to me... Thanks in advance for your help.
Old Oct 7, 2005 | 07:56 AM
1stC5weiss's Avatar
1stC5weiss
Ttt
Old Oct 7, 2005 | 08:15 AM
tramminc's Avatar
tramminc
Old Oct 7, 2005 | 08:18 AM
Mitch C's Avatar
Mitch C
If you don't want to fly cut your pistons you should not have your heads milled .030. You are more than likely going to have P/V issues with the G1 cam if you install it with milled heads without fly cutting your pistons for more clearance. Especially if your cam has an LSA of less than 114.
Old Oct 7, 2005 | 09:48 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
compression equals free horsepower.
Tomuch compression will ruin your day
To Mill Heads or Not?
