mod questions
Oct 7, 2005 | 03:49 AM
mod questions
how much power is gained and is it worth the money for the following mods?
MaxFlow Mass air sensor?
178 thermostat?
ported tb?
MSD wires?
iridium plugs?
descreening maf?
Oct 7, 2005 | 04:31 AM
Probably zero (they may actually cancel each other out), or certainly less than 10.
Oct 7, 2005 | 08:28 AM
Quote:
The ported TB and descreening the MAF are worth while and will give you a bit more HP.
Oct 7, 2005 | 09:07 AM
St. Jude Donor '06-'07-'09-'10
A good cat back exhaust and cold air intake will do more for you.
Oct 7, 2005 | 06:15 PM
Oct 7, 2005 | 06:34 PM
i already have the catback and cold air intake
Oct 7, 2005 | 11:56 PM
178 thermostat? Does nothing for horsepower. Just lets the water flow through the engine at 178 degrees which helps your engine run cooler.
ported tb? Will only help if you have bigger heads to handle the increased air/fuel.
MSD wires? Just gives a hotter spark which helps burn fuel more efficiently.
iridium plugs? Hotter spark/longer life.
descreening maf?[/QUOTE] Lets more dirt into the system.
You should go get a good dyno tune and maybe some LT's.
Oct 8, 2005 | 12:55 AM
No, No, No, No, No, and No, provided you don't have bad plugs.
Mark
Oct 8, 2005 | 04:49 AM
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
No more hp, but iridium plugs are a good investment if you need plugs...........
Oct 8, 2005 | 06:47 AM
Quote:
Mark
Oct 8, 2005 | 08:01 AM
From: Buy USA products! Check the label! Employ Americans
waste of money! MSD = JUNK X 1000
