Inexpensive Cam ?
Old Oct 9, 2005 | 02:26 AM
MawneeC5's Avatar
MawneeC5
Default Inexpensive Cam ?
Is there a Cam that will bolt in without having to spend a fortune on heads/springs/retainers/rods ?
My engine is on a stand at the shop right now about to get a new crank under warranty(spun #5 rod bearing). And it just kills me not to bolt something on it while I have easy access Unfortunately I just got done spending alot of money on the car and the wife is giving me the stink eye if I even mention anymore car parts
A complete cam/heads package would turn me into a monk
So I'm wondering if there are any mild cams out there that I could bolt in without having to upgrade the valvetrain. I"m not expecting monster power gains, I'd be happy with just a tad more agressive tone and idle.
Thanks for any suggestions
Old Oct 9, 2005 | 05:14 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Lots of cam packages out there but no way I would put any new cam in without changing springs etc. You can get a cam package installed and tuned for a little under $2500...so if you are a DIY kinda guy it can be done for less without the tuning which you would have to pay for probably save yousrself about $800 or so....
Old Oct 9, 2005 | 05:23 AM
Mitch C's Avatar
Mitch C
Your car is a 98 if your car has anything like the mileage most 8 year old cars have you should replace the valve springs even with a very mild cam. Even the LS6 cam requires a valve spring swap if the swap is done right.
You might want to see if you can pickup a used mild cam. The money you save buying the cam used you can invest in a new set of valve springs.
Old Oct 9, 2005 | 08:50 AM
Face's Avatar
Face
I really don't recommend this cam, but it's inexpensive for everything. http://www.paceparts.com/index.asp?P...D&ProdID=73032
Old Oct 9, 2005 | 09:22 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
For sale: MTI Stealth I cam
Specs: 220/220 .581-.581@115 LSA (Comp Cams)
Mileage: 9K miles
Price: $200.00 firm+shipping
For anyone who is looking for a cam that has stock idle charactersitics yet makes excellent power, this cam is it! Excellent driveability provided that you have a good tune. Car will drive like stock until you go WOT! I had zero problems with the cam. I decided to go with more duration and a less stealthy cam.
The cam is in excellent condition. I have pictures and original cam card. It is also listed on ebay.
PS- you should get a new set of springs like Comp 918s. For less than 200.00 you have insurance that you wont break a spring and cause 5k engine damage due to a dropped valve.
Old Oct 9, 2005 | 09:26 AM
kumar75150's Avatar
kumar75150
check the boards like ls1tech.com
u can usually find a used ls6 cam with springs
Old Oct 9, 2005 | 11:04 AM
miguel98's Avatar
miguel98
I've heard good and bad things about this cam but on my 2000 Z28 it made 25hp or so has any here one put this cam on a C5 ?
Oh ya will a C5 even crank after a cam swap without tuning?
Old Oct 9, 2005 | 12:15 PM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
Mileage: 9K miles
Ike's car sounded really good with this cam. Not lopey, perfect for someone who wants stealth or like stock drivability. Made good power in his car as well.
The GM Hotcam sucks. I had one in my 01 SS. Made 360-370 rwhp with headers and full bolts ons etc. Drivability sucked, loped and didnt make a ton of power for how it "sounded" My G5X3 is 100x more drivable than the hotcam was.
Yeah it will start and drive fine. My friend Brian drove his 01 for a few weeks untuned with a 224/228 cam. It was drivable.. but a lil tempermental on a hot start. I even started my G5X3 on a stock tune..lol...
Old Oct 9, 2005 | 12:45 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Buy some used springs and it may cost you a motor with no warranty.
Old Oct 9, 2005 | 12:53 PM
AcmeRkt1's Avatar
AcmeRkt1
I'm about to swap out my cam next weekend, I have all of the other parts but was wondering if I needed to change out my timing chain as well. I remember doing it when I changed the cam in my camaro. Also is a double roller necessary? Thanks.
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Of course it'll crank, it'll even run. I put a cam in a friends car last week that had 229 degrees intake duration and 240 something exhaust the car ran and drove for 2 days before he got it tuned albeit pig rich but the car did run and drive.
Old Oct 9, 2005 | 01:33 PM
miguel98's Avatar
miguel98
Hmmmm had a speed shop tell me with a vette any cam swap had to have a tune but i've been infored you dont need one with an LS6 cam swap.
Old Oct 9, 2005 | 01:46 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
A tune and getting a car to run are 2 totally different things, heck even a factory stock Corvette will run and perform better with a little tuning and if you change the airflow thru the engine like when a different cam is installed then it needs to be tuned to maximize the performance gains.
Old Oct 9, 2005 | 02:00 PM
Tony Mamo @ AFR's Avatar
0Tony Mamo @ AFR
Former Vendor
Mileage: 9K miles
Ike's cam + another $250 or so for a new dual valve spring kit good to .600 lift. Money well spent with much better results than the GM cam. Then there's the issue of a competent guy doing the spring install as well (you have to check installed spring heights and add or subtract inexpensive shims as necessary.....also you will need new valve stem seals but they are inexpensive as well).
Good luck....Call me at AFR if I can help you with anything
(818)890-0616 Ext. 109
Tony M.
Old Oct 9, 2005 | 02:04 PM
MawneeC5's Avatar
MawneeC5
Good info here, thanks for all the replies gang
Looks like I may just put it off this time and make a weekend project of it in a few months or so
Old Oct 9, 2005 | 02:37 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
I would buy the springs new and would never trust someone as to the use and mileage on the used springs. Spend a little more for piece of mind.
Plenty of used cams out on ls1tech Then many vendors offer all the parts needed to swap the cam in.
Old Oct 9, 2005 | 10:59 PM
MawneeC5's Avatar
MawneeC5
I registered on LS1tech, man..you werent kidding
Also found this kit, what do you guys think of it ?
http://cgi.ebay.com/ebaymotors/GM-Pe...ayphotohosting
To Inexpensive Cam ?
Old Oct 9, 2005 | 11:08 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
I would recommend reading alot on cams and riding in some cars with cams and decide on what your goals are before buying. I'm not a fan of the hot cam but it does have some advantages mostly being cheap and easy on parts. IMHO you can have a cam just as tame with more power for a little more cash but everything is a trade off.
Old Oct 10, 2005 | 12:36 AM
MawneeC5's Avatar
MawneeC5
This is a pull the trigger or forget it situation... The engine is going back in the car this week.
As far as what I want from a cam. A little more 'pep' and attitude.
My car is a daily driver. A bit more Low/Medium grunt would be nice. And while I dont want my car to sound like a top fueler a bit of lope for attitude would be great. I have no plans to upgrade heads or do FI in the future. I'm not looking for massive horsepower gains or potential..I already have a 9 second toy in the garage
Old Oct 10, 2005 | 04:29 AM
pewter99's Avatar
pewter99
Originally Posted by MawneeC5
I have no plans to upgrade heads or do FI in the future. ..
famous last words...see sig
