spun bearing ?
Old Oct 10, 2005 | 12:24 PM
NXTFAZE's Avatar
NXTFAZE
Default spun bearing ?
Hey fellas,
I got a friend that is having issues w/ low oil pressure in his high compression forged motor in his camaro. The motor has about 4k miles or so on it and has a 100 shot on it. He had it torn down and the diagnosis is a spun main bearing. I told him What would be the cause?
Thanks in advance
Old Oct 10, 2005 | 12:35 PM
frank dupuy's Avatar
frank dupuy
I would look for some answers from the builder of the forged motor. This should not have occured .
Old Oct 10, 2005 | 12:46 PM
NXTFAZE's Avatar
NXTFAZE
Thanks Frank, I was afraid you were gonna say that.....
Could not having enough oil cause a spun bearing?
Old Oct 10, 2005 | 01:21 PM
Mitch C's Avatar
Mitch C
Not enough oil and high oil temps can cause spun bears.
Very high RPM can also cause spun bearings.
Old Oct 10, 2005 | 01:57 PM
NXTFAZE's Avatar
NXTFAZE
Thanks guys.....
Just hoping we can find the cause so it doesn't happen again.
Old Oct 10, 2005 | 04:04 PM
NXTFAZE's Avatar
NXTFAZE
Just did some more research.....
Spun bearings is not uncommon when revving over 7,000 rpm from what i read from some drag racers..... anyone else have any input.
Old Oct 10, 2005 | 04:48 PM
RED99's Avatar
RED99
I'm not sure if you will ever know for sure what caused it. But low oil pressure sure didn't help it. I would advise having the Mains aligned bored before putting it back together, just to be safe. Look at the oil schemtics of the motor, and see which main is on the last of the feed line. If it was that main, then it probably was due to oil pressure lost. How did all the other bearing look? "I THINK".....it's usually it's the Rod bearing that spins.
Old Oct 10, 2005 | 05:22 PM
GUSTO14's Avatar
GUSTO14
Originally Posted by RED99
... If it was that main, then it probably was due to oil pressure lost. How did all the other bearing look? "I THINK".....it's usually it's the Rod bearing that spins.
Unfortunately the low oil pressure is usually the result of the spun bearing, not the cause. Many times it's the first indication... followed closely by that old knocking sound.
GUSTO
Old Oct 10, 2005 | 11:14 PM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
Lots of things can cause a spun bearing including poor clearancing, improper torque or torquing procedure, debris in the crank etc.
Old Oct 11, 2005 | 12:16 AM
frank dupuy
Sorry for being so abrupt on my first response. The truth to the matter is there can be many reasons for the crank to spin a bearing besides lack of oil. The only thing to do now is remove the crank while checking torque on the bearing caps. If bearing caps were not torque to specks one probable cause. The bearing is already destroyed but it could have been faulty or burred while installing the crank or just not installed properly. Crank should be checked for any under or over size journals. Also need to check block bearing caps for sizing and alignment. When building up a motor you need to check everything as the saying goes you are only as strong as the weakest link.
Old Oct 11, 2005 | 01:19 PM
NXTFAZE's Avatar
NXTFAZE
Thanks for all the input. If I was able to post some pics of the bearings......could anyone tell what was the cause?
Old Oct 11, 2005 | 04:21 PM
mdhmi's Avatar
mdhmi
Who built the motor?
Mark
Old Oct 11, 2005 | 11:42 PM
7.0sc SuperVette's Avatar
7.0sc SuperVette
From: Sunny Earthquake Country, USA On the Left Coast (which is becoming more Right!)
Default Bearing crush...
Proper bearing crush provides the radial force to hold the main bearing in place. If the line bore was to loose, or the bearing not long enough (transversely) or a machining chip held cap up on torque down, it will spin.
Roy
To spun bearing ?
