Will Bilstein's lower...
Old Oct 10, 2005 | 05:47 PM
GMvert's Avatar
GMvert
Default Will Bilstein's lower...
the car more after having lowered on stock bolts only, or do I have to cut front bushings and buy longer bolts for the rear to get the look I want?
Old Oct 10, 2005 | 06:02 PM
Old Rotor Head's Avatar
Old Rotor Head
I'm lowered on stock bolts and didn't notice any change in ride height. As far as I know, shocks only dampen the up/down movement and have nothing to do with suspension height.
Old Oct 10, 2005 | 09:03 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
correct unless they are bottomed out and holding the car up like crutches. They would have to be the wrong size to do that.
Old Oct 11, 2005 | 10:45 AM
DJMRTS's Avatar
DJMRTS
Yes you will need to cut the front bushings and maybe go with longer bolts in the rear. Bilstein Sport shocks are designed to be used for lowered suspensions.
To Will Bilstein's lower...
