Brake Bleeding Question
Old Oct 10, 2005 | 08:26 PM
LS7's Avatar
LS7
Default Brake Bleeding Question
I'm waiting for my "One Man Break Bleeding System" to arrive from Griot's Garage.
It's a system where you create a vacuum within a canister and open a valve to let the brake fluid drain into a self containing canister.
My question is; Can I bleed the brake system myself in my 2000' C5 or does the Dealer have to do this?
I'm not sure with all the Traction Control and Ride Control options if this is something that can be done by myself. Does the Vette have to be running?
If this is something I can do myself, does anyone know the correct sequence or procedure?
i.e.(RR,LR,RF,LF). Any help would be appreciated.
Old Oct 10, 2005 | 08:35 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
You'll have no problems doing it yourself, but for some years the bleed order is different and I can't remember it off the top of my head.
Old Oct 10, 2005 | 09:09 PM
Dustie's Avatar
Dustie
RR-LR-RF-LF is correct for 97 to 00 cars. Don't let the master fluid level get low....
Old Oct 10, 2005 | 09:15 PM
JGVette's Avatar
JGVette
Yes, you can bleed without affecting ABS etc as long as the master cylinder doesn't get to low. I used a Motive Power Bleeder but Griots makes great products, so you should be set there. As long as you are going to bleed you may want to put in a higher performance fluid. I used ATE Blue Racing Brake Fluid (Dot 4). It comes in blue and amber. Besides being a better product, it is helpful in knowing when you have fully bled the line. Also, now is the time to consider ceramic or high performance brake pads and/or Stainless Steel lines. Good Luck.
Jay G
98 Pewter Coupe
http://www.vette1.net
Old Oct 10, 2005 | 09:23 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
I have found the "push the fluid throught the master cylinder" type bleeders are better than the "draw the fluid through the caliper" type bleeders.
Hopefully... whatever you have purchased will work out best for you.
VR
Old Oct 10, 2005 | 11:17 PM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Be careful changing DOT numbers. Some are compatible, some aren't. Do your homework. I believe DOT 3,4, and 5.1 can be mixed. But DOT 5 requires a full flush and cleaning of the system.
Old Oct 10, 2005 | 11:25 PM
SLPRC5's Avatar
SLPRC5
Rats I think I bleed mine wrong for the fronts. There seems to be no problem stopping. What sort of problem can happen if bleed wrong?
Old Oct 10, 2005 | 11:37 PM
rikhek's Avatar
rikhek
Potential for leaving air in the system. if it's braking straight you should be alright.
Rick
Old Oct 11, 2005 | 12:40 AM
SLPRC5's Avatar
SLPRC5
Rick
Yep straight as an arrow..no BS light warning or anything...Thanks for the reply Rick.
Rsty
Old Oct 11, 2005 | 01:13 AM
1KLRTOY's Avatar
1KLRTOY
My 01 factory manual says, RR-LF-LR-RF, no matter what sequence you use you won't get air in the system unless the master cylinder runs out, you'll just use more fluid to flush the system
Old Oct 11, 2005 | 02:19 AM
SLPRC5's Avatar
SLPRC5
Thanks for the info....
Old Oct 11, 2005 | 10:43 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
2001+ is different.
I just did my 97' & 00' coupes........
http://forums.corvetteforum.com/show...916&forum_id=1
http://forums.corvetteforum.com/show...917&forum_id=1
To Brake Bleeding Question
