Bigger Rear End - Pro vs Con?
Old Oct 10, 2005 | 10:55 PM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Default Bigger Rear End - Pro vs Con?
I currently autocross and drag my 04 C5 with an A4 tranny. I am thinking of upgrading the rear end to 3.42 or 3.73 (from the 3.15 current). Also, I drive the car on the street about 10k per year. I would like to know the pros and cons of a bigger rear end. Also, which size is better for my usage and why? Oh yeah, and what is the meaning of life?
Old Oct 11, 2005 | 02:42 AM
doje's Avatar
doje
ttt
Old Oct 11, 2005 | 04:10 AM
doje's Avatar
doje
ttt
Old Oct 11, 2005 | 04:55 AM
Mitch C's Avatar
Mitch C
I have had 3.15s, 3.42s and now 3.73 gears. If you are going to swap just gears go with 3.73s. There isn't enough of a difference between 3.15s and 3.42s to warrant the trouble and cost of just a gear swap.
However if you are also swapping your T/C going to 3.42s are much more cost effective.
The Pros of going with a bigger gear is better acceleration. Bigger gears will also make a high stall T/C feel tighter.
The cons are more RPM and lower fuel economy.
Old Oct 11, 2005 | 05:44 AM
ChipN's Avatar
ChipN
I went from 3.15 to 3.42 on my '04 A4 this year and didn't notice much of a difference - at least not as much as I had expected / hoped for. I also have Z06 rims & tires (F1 Supercar) so it is possible that with the stock runflats I might have noticed more spinning than I do.
The biggest difference that I noticed was cruising around at 78 - 81 mph I hear a "drone" sound. This problem existed before but maybe occurred at 5+ mph higher (outside the range of highway crusing for me). Anyway, my concern with lower gears would be that this would occur in the low to mid-70s and that would drive me crazy.
Just my $0.02.
Chip
Old Oct 11, 2005 | 03:51 PM
doje's Avatar
doje
Default More Opinions Needed
ttt
Old Oct 11, 2005 | 04:02 PM
ChipN's Avatar
ChipN
What are your performance goals? I would think that this would drive your decision more than anything. I don't think that either is a bad choice, but one may be better than the other depending on what you are looking to accomplish. Just my $0.02
Old Oct 11, 2005 | 07:58 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
I went from 2.73 to 3.42, 2600stall TC.Wish I went 3.73's.Go 3.73
Old Oct 12, 2005 | 03:08 AM
CORTVET's Avatar
CORTVET
From: Putting a 50¢ sticker of the U.S. Flag on a $50,000 import does not make one a patriot.
I have a stock TC and 3.73's. I now want some 4.10's!
AZC5
Old Oct 12, 2005 | 03:43 AM
AZBrewer's Avatar
AZBrewer
I had 3.42 in my 02 - manual trans. I switched to 4.10's and holly cow, what a difference. Then I went with a ATI procharger - the car was faster than traction, I would spin them in 3rd gear. Now I have nitto 555RII 305's in the back, 285's in the front. I'll tell ya, if I had a back seat I'd be sitting in it.
Its sooooo cool.
Old Oct 12, 2005 | 08:40 PM
doje's Avatar
doje
Default More opinions needed
Would I see a sihnifigant difference in an autocross situation? Or just in drag racing?
Old Oct 12, 2005 | 09:29 PM
Lovin It!!! - C5's Avatar
Lovin It!!! - C5
High gear ratios have significantly better torque and acceleration but you sacrifice top end speed, gear strength and incur more "whine" at top end. (You lose gear tooth strength due to the teeth being thinner as your ratio goes up.) 3.72s should be great for autocross and still give you a major improvement in your drag times, 4.10s would be optimal for drag, but I think you'll be lacking in the top end.
Old Oct 12, 2005 | 09:42 PM
EHS's Avatar
EHS
Bigger rear end?
Well, yes. most guys think that a bigger rear end is better.
Depends. I prefer them on the smaller side.
Old Oct 13, 2005 | 07:52 PM
doje's Avatar
doje
Default More opinions wanted
Old Oct 14, 2005 | 06:50 AM
cenzo's Avatar
cenzo
Originally Posted by EHS
Bigger rear end?
Shape can be as important as size...I think.
Seriously, do the 373s if you're gonna spend the money. Remember, your top speed will be reduced to 166 intead of 178 mph.
Old Oct 14, 2005 | 09:53 AM
Lovin It!!! - C5
But proper movement is also a critical aspect. IMHO
To Bigger Rear End - Pro vs Con?
