Average MPG Resetting Itself
Old Oct 12, 2005 | 08:29 AM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Default Average MPG Resetting Itself
It may be time for a new battery. Startups have been semi-slow cranking for a while now, I have been getting wheel speed sensor DIC messages (C1226) more frequently and about the last week or so the Average MPG meter has been resetting itself after sitting overnight.
I'd say its time to invest in a new one...
Old Oct 12, 2005 | 08:38 AM
dunbindun(tov)'s Avatar
dunbindun(tov)
Heed the warning. Most batteries go t*ts-up with no prior notice. Consider yourself lucky. Make sure alternator is putting out good volts too.
Old Oct 12, 2005 | 08:58 AM
5 Liter Eater
St. Jude Donor '11
Alternator looks good. Volts prior to startup are ~11.8. After its running its ~18.8-14.2.
Old Oct 12, 2005 | 11:24 AM
rws.1's Avatar
rws.1
Looks like the voltage readings are indicating a battery. To be sure most autoparts store will do a free on the car electical system check that tests both the battery and alternator....
the next question is which battery?
Optima Red top ?
Old Oct 12, 2005 | 02:31 PM
5 Liter Eater
St. Jude Donor '11
I don't know why everone gets all hopped up about fancy batteries. I know it's a 'vette but to me a battery is a battery is a battery (assuming it is not a leaky stock Delco). It will more than likely be a Pep Boys or Autozone special.
Old Oct 12, 2005 | 02:45 PM
NSTG8R's Avatar
NSTG8R
and yeh ... mine has been doing the same .. i found if i dont drive the car at least once a day it'll be dead. .. guess how i solve that problem.
To Average MPG Resetting Itself
